READ THIS: Rear Camber is off due to lowering springs
So I am sitting on S-Techs. and the rear camber is drastically off on the passenger side from the driver side. I havent had it on a rack to check what its at, but if I was to guess, I would say the driver side is at like -1 degrees and the passenger is at like -3... its cambered enough where you can visibly see it being different between the two...
Again, I havent looked, but I have heard that we dont have any adjustability in the rear... sooooo, my questions are as follows: anyone else with S-Techs notice a difference in the rear camber on thier own tC2? and anyone have any ideas on what can be done to fix it?
I just looked at the TRD Spring install PDF and at the end regarding alignment for the rear it mentions it's not adjustable. Oh really Toyota!? I haven't seen how the setup is for the assembly to get an idea what can be done.
I saw the post mentioning camber bolts, I know the fronts they have different bolt combinations to get the alignment in spec, maybe that can be done for the rear.
I have the same issue on mine. I don't know why one would be off more then the other on the same drop but mine is -3 on my passenger and -1.5 driver side in the rears. I'm just waiting on some camber arms to be available for our cars
Not sure if this is what you are looking for:
http://www.ptuning.com/html/Item-Des...9&ModelDesc=tC
It says FRONT, but... maybe you can get a hold of the company and see if they are doing anything for the rear as well?
there is a shim kit that could be used that any quality alignment shop knows about. it is a plastic disc that rotates and I believe it could do +/- 1.5 degrees.
you could even have some camber plates made that bolt up behind the hub. something simular to realcamber.com
he was doing some -3 or -5 plates for the xb2 which I would assume is running the same solid beam rear set up.
