APR STAGE 1 TURBOKIT FOR VW MKV 2.0T's
Ok... I just called APR and they said they will be releasing the first turbo stage kit for the GTI within two months from now. It will give you 300 to 350hp for your Jetta/GTI!!! They guy also mentioned that a stage 3 will be released towards the end of the year, if not, then the first quarter of next year which will give you 400+hp . With those kind of numbers, your going to need some serious grippage for a FWD GTI. Now for cost................around $3400 for the stage 1 kit. As for the stage 2 or 3...N/A....
Torque stear is when a car has so much power and not enough rigidity in the suspension, differential nor front for that matter so each time you go around a curve the car pulls hard and the steering wheel can act like it has a mind of its own. Others here can probably better define it though.
asI am not so sure what the GTi has stock, so somewhat like Skunk said you may need a stronger differential and put in a larger sway bar to combat any potential torque steer from that Stage 1 kit. I mean you still want to maintain the GTi's balance and nimbleness?
Torque-steer is typical in front wheel drive cars with a lot of power. Basically when you floor it and the the wheels spin, they will have the effect of tugging the steering wheel to the side because the drive wheels are the same as the turning wheels. A good suspension setup, motor mounts, etc can help combat this problem but with 300+hp you're going to have it no matter what you do really. Wheelhop and wheelspin will also obviously be issues (though I think I heard wheelhop is limited in the new GTI), as will upgrading your clutch. The stronger aftermarket clutch will often be harder to operate as well, making it a pain in traffic.
well i'll just ride in my stock clutch til it goes then i'll get a SPEC Stage 2 or 3 clutch...i dont think the stage 1should give me much torque steer the stage 3 i'm sure u would have to change the engine mounts and sum good suspension mods..
I already have H&R coils soo i'll put sum sways and should be good..
i mean my friend has a gti 1.8t with a APR stage 3 plus kit thats about 290whp and 310ft lbs tq and he has just lowering springs and just changed his clutch to a SPEC stage 2 or 3 not sure...he doesn't have a problem with this and the new gti's are heavier soo it should help out..i think APR knows what they are doin
this is my CANDY WHITE MKV GTI
mods - giac 03b+ software, 2.5" Techtonics Tuning TBE, Forge BOV spacer, H&R coils
Here's a video of my car i made after i got my exhaust put in..... http://media.putfile.com/mkv-gti-turboback
My ex-girlfriend's brother has a 20th Anv GTI with ecu/turboback/coilovers. I know he upgraded his clutch, and got motor mounts and some other mod I forgot (LSD I think, but I don't remember) to curb the wheelhop. I rode in it with him, and indeed, there was no hop at all; just spin. I don't know how bad his torque-steer was because I didn't drive it, but he said he felt it a bit.
I imagine with more power like that it'll be somewhat pronounced in the new car, if only because the 2.0T is such a torque monster to begin with.
yaaa i know eventually i'll change the clutch to a spec stage 2 or 3 whenever the stock one gives up and plan on puttin a LSD if i get the turbo upgrade and engine mounts jus to do it right...but thanks for being polite and and explaining to me everything... :D
SouthernCaliTC
09-15-2015 01:58 AM
marsman328
Regional - Pacific Mid
07-28-2015 09:43 PM
