Agency Power Light Weight Pulleys xA xB xB2 tC
#182
TC $126 shipped
Reinventing the wheel is something we do not do. However, making the wheel lighter makes it easier to spin. Lightweight crank pulleys have proven horsepower and torque increases time after time. You can get pulleys under driven or same size as stock. We at Agency Power choose to make all of our crank pulleys the same diameter as the factory but reduce the weight. This type of design will not affect alternator power for the enthusiast running extra stereo equipment. This retains the factory belts and fits with no modifications.
Our Scion TC pulley is CNC machined 6061 aluminum. Properly broached and includes the timing mark for a balanced OEM quality fit. The pulleys are then media blasted for a satin silver finish and lasered with the Agency Power name (not shown). Our Agency Power pulley weighs about 3.5lbs lighter then the factory pulley. Reducing rotating mass gives the Scion TC a gain of 10 horsepower and an increase in torque by 11 ft/lbs as Dyno proven.
Overall driving impression is an increase in throttle response during acceleration. The entire power band gains performance and drivability remains the same. The Agency Power Scion TC pulley will give you the extra power you desire!
XA/XB $126 shipped
Self expression, fashion, function, style. These are all words that describe the Scion xB/xA and its owners. But like any car enthusiast, Scion xB/xA owners want power. Agency Power has continued its success in performance products with a brand new lightweight crank pulley for your Scion xB/xA. This pulley saves almost 4 pounds over the stock unit. Since the pulley is kept the same diameter as stock, you retain the factory style belts and incur no alternator affects for your custom car stereo system. Less rotating mass equals faster throttle response, increase in horsepower, and torque. With this pulley on your Scion, you will see gains of up to 9 wheel horsepower as tested.
The pulley is made from CNC machined T6061 aluminum that is anodized in red or blue. The pulleys are balanced and tested to fit perfect every time, and are a direct replacement for your factory pulley.
Contact with any qustions.
Greg B.
gregb@carcandymotorsports.com
