Ingalls Rear Shock Tower Brace for tC
Ingalls performance suspension components introduces a rear shock tower brace for the Scion tC. Stiffens the rear unibody section for more predictable and improved handling, decreased chassis noise, increased grip. When installed, this Ingalls rear shock tower brace allows access to the spare tire.
Mounts low, on the floor of the trunk. Mounts to the upper rear shock bolts. Installation does require a little drilling....but you can handle that!
If you have stiffened up your suspension on your Scion tC, you want to make sure that the suspension is doing all the work, not the unibody flexing.
In stock ready to ship.
Also the drilling of the holes are just enlarging the existing holes, no need for drilling new holes. And if not inculded, you might want some 1.5" washers for the bottom, because just using the nut will bend/indent the frame.
Also not posted is that you need to cut/trim your 2 foam pieces a lil to go over the brace since this is a 4-point bar as to the regular mostly useless 2-point bars(i.e. greddy, weapon r, etc...)
