PTUNING: Spec-SS Competition Return-Style Fuel Systems
The PTUNING Spec-SS Competition Return-Style Fuel System is a must for forced induction applications. Our system is designed to allow fueling to the engine beyond the capacity of the factory return-less fuel system. Featuring an in-tank Walbro 255 LPH HP fuel pump and -6 lightweight braided racing feed and return lines, this kit will support 500+ horsepower. Our kit is designed as a simple bolt-on (now comes with factory siphon assembly).
Design Features:
- Genuine Walbro fuel pump
- Lightweight braided racing fuel lines
- AN connections w/ Factory-style quick connections
- Adjustable boost sensing fuel pressure regulator
- Built in fuel pressure gauge
- Billet aluminum, CNC machined, anodized, laser-etched fuel rail
- Upgradeable to PTUNING Spec-RS/Spec-RSII Competition Fuel System with swirl pot and twin pumps for 900+hp.
Kit Contents:
- In-tank Walbro 255 lph high pressure fuel pump
- PTUNING lightweight braided -6 racing fuel lines with aluminum AN fittings
- PTUNING custom return-line conversion kit
- PTUNING billet fuel rail
- PTUNING billet FPR bypass plug
- FueLab mini EFI fuel pressure regulator
- Liquid-filled 0-100 psi fuel pressure gauge
- Factory-style fuel quick disconnects
- All necessary fittings, clamps, hardware and detailed instruction
PTUNING Spec-SS & Spec-RS Fuel Systems
Design Features:
Kit Contents:
Thank you.
We have 3 Spec-SS kits left (2 red & 1 black) if you are interested.
It's not easy, but it's not hard either. It's just take a bit of time.
If you ever have any technical or install questions on any of our products, please don't hesitate to contact us. We will be more than happy to help.
