Exclusive Sponsored Sales site sponsors with special deals...
ROTORA BIG BRAKES SPECIAL - SCION xA / xB!!!
Old 08-16-2010 | 07:53 PM
1fastscion's Avatar
Default ROTORA BIG BRAKES SPECIAL - SCION xA / xB!!!
Attention Scionlife Members:
FastScions.com is having a killer deal on the Rotora 4-Piston Front Big Brake Kit for the Scion xA / xB 2004 - 2006!!!
http://www.fastscions.com/rotora-4-p...RBK042.01.aspx
The Rotora 4-Piston Front Big Brake Kit for the Scion xA / xB provides the best possible braking performance and is made of the highest quality components available.
The Rotora Big Brake Kit includes all necessary components for a complete installation. 13" Slotted Front Rotors (Left & Right), 4-Piston Red Calipers (Left & Right), Stainless Steel Brake Lines (Left & Right), High Performance Ceramic Brake Pads (Left & Right) as well as Mounting Brackets and Miscellaneous Fittings, Washers, etc.
RETAIL PRICE IS $1550.00, FASTSCIONS.COM IS OFFERING A BLOWOUT PRICE OF $999.99 SHIPPED!!!! YOU CAN ALSO ENTER YOUR SL COUPON CODE TO SAVE AN ADDITIONAL $50!!!!
Take advantage of an awesome product at an unbeatable price!!! This Scion xA / xB Rotora 4-Piston Front Big Brake Kit is good in stock and ships SAME business day!!! (Red Calipers, Slotted Rotors Only)
ROTORA 4-PISTON FRONT BIG BRAKE KIT
Fits: Scion xA / xB 2004 - 2006
Part Number: RBK042.01
Made of billet aluminum alloy and CNC machined to ensure the highest quality; Rotora's high performance brake system for the Scion xA xB enables superior brake modulation while improving overall pedal feel to ensure equal distribution of weight transfer when braking. To achieve this proportional front-to-rear brake bias, Rotoras opposing piston calipers are fine tuned by increasing the clamp load to the optimal level while utilizing the stock master cylinder to retain overall front-to-rear brake bias. Rotoras full big brake system design delivers excellent initial bite, exceptional modulation, and consistent pedal feel for street and track use applications. All systems are ABS compatible and direct bolt on replacement with minimal modifications required.
COMPONENTS/FEATURES:
-Rotora billet aluminum alloy 4-piston racing calipers with sequentially sized piston bore sizes engineered to each specific vehicle.
-Rotora billet aluminum hat with “floating” disc assembly to reduce heat related stress and unsprung weight.
-Rotora 330X30mm 2-piece heat treated directional vane disc system to improve airflow/cooling under severe braking.
Slotted or drilled & slotted oversize discs up to 16” (405mm) to ensure equal heat dissipation and increase thermal capacity while relieving the disc and brake pad surface free of excess debris.
-Rotora ceramic formulated pads designed for extreme street and track application with high co-efficient of friction and high temperature fade resistance.
-Rotora DOT compliant stainless steel braided brake lines to improve stiffer pedal feel and prevent brake hose expansion.
-Rotora carbon steel (SC45) mounting brackets (depending on application) and hardware.
www.fastscions.com/rotora-4-piston-front-big-brake-kit-scion-xa-xb-RBK042.01.aspx
Old 08-17-2010 | 05:12 PM
1fastscion's Avatar
good in stock!!!
Old 08-18-2010 | 10:46 PM
1fastscion's Avatar
best bang for your brake buck!!
Old 01-31-2011 | 09:32 PM
1fastscion's Avatar
more kits . . with price reduction
VCUBoy714
Scion tC 1G ICE & Interior
01-05-2015 08:46 PM
AbsoluteRedtC
12-31-2014 06:18 PM
JM Auto Racing
12-19-2014 06:36 PM
DenZinz
32
02-17-2004 06:56 PM
scioninla
14
10-18-2003 03:46 AM
Quick Reply: ROTORA BIG BRAKES SPECIAL - SCION xA / xB!!!
