Scion FR-S Perrin Rear Sway Bar
Strictly Scionized
Description:
A stiffer sway bar reduces body roll when cornering, allowing for more of the tire to grip the road, giving you better handling, and increasing driver confidence & performance. PERRIN sway bars are made from solid steel using precision bending equipment. The entire bar is heavily powder coated to fight corrosion and give it that great red finish. We laser cut and MIG weld our bar ends for precise placement. This type of bar end will never fail and gives us greater precision over competitors. (Competitors who smash the ends of their bars flat)
PERRIN Performance sway bars incorporate multiple endlink mounting holes which allow the installer to custom tailor your driving experience. Perrin sway bars increase stiffness by a minimum of 100% overstock. Adjusting the endlink mounting position can increase that stiffness to as much at 400% over stock. *varies by model. Perrin Performance sway bars feature centering rings that prevent sway bar movement in hard cornering. This keeps your sway bar centered and ready for the next corner.
All sway bars include polyurethane bushings for a crisp response and better turn in. Special pockets carved into the bushing surface extends the interval between re-greasing.
Perrin Performance sway bars come in three different sizes. 19mm, 22mm, and 25mm. Driving enthusiast will enjoy the feel of a 19mm bar while true racers will like the rigidity of the 22mm and the 25mm. The softest setting on the 22mm is reflective of the stiffest setting on the 19mm bar.
Includes:
- Perrin Rear Sway Bar
- Energy Suspension Bushings and grease
Product Page:
ScionLife Editor
11-25-2014 03:00 PM
