<-----Stoptech Stage 2 tC----->
Stoptech stage 2 brake upgrade
Slotted rotors prevent glazing of the pads, add bite and improve wet and dry braking performance. StopTech's SportStop rotors have a durable black coating on the non-swept areas of the rotor to prevent unsightly corrosion, and quality is assured as the rotors are manufactured to meet or exceed all OE specifications.
Stainless steel brake lines improve pedal feel and reduce the amount of time between applied pedal pressure and actual deceleration by preventing expansion, which stock rubber flex lines allow.
High performance street pads provide you with higher resistance to fade, higher maximum operating temperature, and better initial bite to allow consistent deep braking into corners. Motul RBF600 brake fluid increases both wet and dry boiling points and prevents boiling even under the most severe operating conditions. Good for street and autocross.
Kit Includes:
StopTech's SportStop slotted rotors,
StopTech stainless steel brake lines,
Axxis Ultimate street performance pads
3 bottles of Motul RBF600 brake fluid.
Rotors, lines and pads are for both front and rear. FITS STOCK CALIPERS AND WHEELS.
Ships same day if ordered before 5pm (MST). Tracking number sent within minutes
PM me for a deal.
Kit Includes:
PM me for a deal.
