Soldering Info / Tips
Originally Posted by VIP_tC
Its been awhile since Ive done any soldering and boy am I rusty... lol. Anyways I took apart an old broken dvd player from 1997 and started messing with it but I was having some trouble removing the pieces that were soldered on it. Ill keep practicing. Also, I bought a 15 watt iron and the smallest solder I could find but it isnt the 60/40 like you suggested... I bought this:
http://www.radioshack.com/product.as...%5Fid=64%2D035
Will this work ok? It is 62/36/2 instead. The other thing I noticed is that it is talking longer than 1-2 seconds to melt the solder on the board, and I am also having trouble wicking it up with the desolder braid.
Most of this is new to me since most of my solder experience is just soldering basic wires and such. I suppose I need to keep practicing...
Hope this helps!
Originally Posted by firesquare
is that cold/heat soldering tool any good? i had used many soldering irong before. like electric and butane powered. is it worth spending my 19.99?
DO NOT GET THE COLD HEAT IRON!
You WILL blow your gauges with that thing! If you're repairing jewelry or soldering wires together it's ok but if what you're soldering has sensitive electronic components, it will damage them.
The Cold Heat iron works by using whatever metal you're soldering to complete the circuit for the iron so it will heat up. In doing so it will spark as soon as it comes in contact. Not to mention that iron heats up FAST and HOT and you run the risk of pulling the traces clean off the board which is also fatal.
Get a cheap $15 15-20W iron from RadioShack, that's all you need.
sounds good thanks for the tip! i would use the solderion iron for general crap as for some interior stuff too.
will the 15W be hot enough to solder stereo wires and small stuff like that?
is their such thing as a variable wattage Soldering iron?
More expensive lab setups have a variable temp setup. But that is a little more than you will need at home (especially for the money they cost )
If you cant find the one I mentioned above, just buy one 20w and one 40w. They are very cheap.
I had zero experience with soldering so I went to the local electronics store and bought a starter kit. It came with the iron, stand, spounge, solder, and two practice boards. I practiced on the two boards while waiting for the leds to come in. It became very easy to do it after the first board. I would highly recomend to anyone that has never this before. So I did the led conversion last night without a problem. that is until I put the tach gauge back on! I have reset it but the needle keeps falling back down, so it reads 0 rpm at idle. I tried to fix it 5 times now. Can anyone help?
Yep, sounds like it is pushed down too far. I did that at first with my tach... it worked but stayed at 1000 rpm when I shut it off Just loosen it up a bit as jmiller said. Glad to hear that the soldering went well! I had my first real tough hand soldering experience in my first electronics job during college. When troubleshooting bad equipment, I often had to replace 144 pin flat pack processors (which cannot be baked on as they are when constructed because all of the rest of the components would be damaged). Soldering 144 pins that are only about .010 inches apart will drive you mad!!!! But good practice nonetheless
another little tip (hmm didnt realize how long this has been posted)
If soldering somthing and you are worreid about heat affecting the part... get one of those wires with aligator clips at each end.. put one side to a large piece of metal (other than what your soldering), and the other side on the lead between your connection point and actuall componant...
it will help "bleed" the extra heat before reaching any sensitive equipment.....
teachers at tech school recomendend that on just about any soldering job that wasnt just to pieces of wire being connected...
^^ Good addition, and something I forgot to mention. Using some sort of heat sink is very beneficial when you can fit one on somewhere, especially when you are still learning and tend to overheat the connection more. But this is always a good technique when feasible.
Many thanks to engifineer for all the good soldering tips'. My '06 Tc is on it's way, but I'm already thinking about taking out the stock Pioneer head unit. I already have an Alpine CDA 9833 with an Ipod interface (KCA 420 i) andf a Sirius interface as well. I plan on transferring that system into the Tc.
My dilemma is: How do I retain the functionality of the steering wheel audio controls once I swap in the Alpine?
It's such a cool feature that I don't want to lose.
My plan: 1) Find the harness for the steering control.
2) Open the infrared remote control that came
with the Alpine HU and solder the harness to
the corresponding points on the circuit board.
I'm no engineer, but I believe that this can be
done with a little bit of patience.
If anyone has any suggestions, please let me know.
umnitza
07-25-2015 07:54 PM
