Lexus SC430 2nd-Gen Owners Lounge 2002- Flagship Sport Coupe
Painting headlight housings black?
Old 02-10-2006 | 02:56 AM
scionlife's Avatar
Founder
Default Painting headlight housings black?
Has anyone taken apart their headlights and painted the chrome housing black? I bought an extra set of headlights on eBay and want to do this.
Old 02-10-2006 | 03:56 AM
stick_1NZ's Avatar
Darren, I don't own a Lex but I've done it on my Accord Headlight. I did the "oven technique" and used Krylon BBQ high temp paint in black for the housing.
I see you're going JDM eh. Good luck.
Old 02-10-2006 | 04:43 AM
scionlife's Avatar
Founder
Any links to a good DIY so I don't melt my lenses?
Old 02-10-2006 | 04:56 AM
stick_1NZ's Avatar
Here's the DIY I followed when I did my black housing:
To seperate the headlights, I preheated an oven to 300 degrees and placed the headlight on a baking sheet with some aluminum foil. (Don't want to upset mom for using her baking sheets for car plastic, now do we?) After about 5 minutes you could pry the housing apart using a flat head screwdriver. Some parts of the housing are a little fragile so don't be too rough. There is a reinforced area on the bottom, about 2 inches in from the inside corner that I could torque on pretty hard and not crack anything.
Now comes the taping off. You'll probably need to rig up something from what you have laying around the house. I had one of those lint rollers that is basically a wide strip of masking tape. I rolled it on my shirt to pick up some lint and make it a little less sticky. I tried using stronger tape and where it touched the side, it ended up pulling off the chrome. Luckily it was an area I was going to paint, but be careful when you do this. I masked off all the areas that I figured were involved in focusing the light. I also masked off the top since nobody will see that it's unpainted. So basically the bottom, front, sides, and the low beam cap got painted. You can see this in the photos above.
To reassemble the headlights you can optionally run a thin bead of silicone sealant to make sure you have a good seal. I skipped that and pushed the housings together as thight as I could. Put them in the oven, same as before, and after five minutes you could push them together and they'll be properly seated. Snap the 4 little metal clips you took off before to help hold the housing together while it cools. Then just reassemble everything in the reverse of how you took it off. I suggest leaving off the two button/screw fasteners under each headlight off, in case you want to take the bumper off again in the future.
The paint I used was black BBQ paint. $3.99 from the local AutoZone. It can withstand temps up to 1000 degrees, and drys quickly to a beautiful satin black finish.
Link for the full write up:
http://cryogen97.net/howto/blackhousing.html
Here's an old pic of the headlights:
Old 02-10-2006 | 08:27 PM
scionlife's Avatar
Founder
Any leaking or moisture problems after?
Old 02-10-2006 | 10:16 PM
stick_1NZ's Avatar
Never had any....all I did was re-sealed it with a thin application of silicone. It's been 3 years and no leak. Good luck Darren.
Old 03-17-2006 | 10:24 PM
VinnyQH's Avatar
let me know when you are gonna do this darren, cause i want to do my tailights at the same time, we can have a baking party!!
Old 05-09-2006 | 07:17 AM
scionlife's Avatar
Founder
Yeah... I have been too scared to do it. I'm so lame.
Old 05-09-2006 | 07:24 AM
sONicRoK1's Avatar
i think i remember that accord from superhonda.com
i was kind of a lurker there....also a previous 5th gen owner.
S7ephavs
03-22-2015 01:09 PM
JPuehl
Scion tC 2G Wheel & Tire
01-22-2015 03:44 PM
umnitza
12-01-2014 07:26 PM
scioninla
31
01-10-2004 01:56 AM
happies713
10
12-22-2003 01:27 AM
Quick Reply: Painting headlight housings black?
