Blue temp light
Old 01-05-2004 | 07:07 PM
TheRedBox's Avatar
Originally Posted by bBted
i warm up my car every morning til the blue light turn off...
i tried not to, but the shifter feels weird...hard to put in gear...dunno why
Agreed. But i still drive it like that. :D
Old 01-05-2004 | 07:08 PM
hahajoey's Avatar
i believe idling/warming up your car for a long time
will leave carbon build up and deposits at a higher rate
than just driving on your car easily till it gets warm.
i can be wrong.
Old 01-06-2004 | 12:06 AM
mach5's Avatar
warming up your car is ok, its safe and there is NOTHING wrong with it.
driving with your car cold is ok after about a minute or so if you take it easy
what do you think we do with inspections?!?!?!? we run a cold car!??!?!?
what do you think we do when we drain and replace coolant???? we put in coolant with the motor off and pull it out??!??! WRONG we put in coolant and let the car WARM up and then put in more coolant when needed.
oh no, all the techs must be destroying you cars, its a big plan
same thing with tranny fluid, we let the car warm up to operating temp
there is nothing wrong with letting your car reach operating temp or driving it cold under light load
please dont tell people wrong information
Old 01-07-2004 | 06:55 PM
Kendo's Avatar
Default Blue Temp Light
Hey Franky, I'd check out the bulb on your car. That light always comes on when I cold start in mine and I'm over 5k miles already.
Old 01-08-2004 | 01:38 AM
Inazuma's Avatar
Default Re: Blue Temp Light
It was weird, when i left work today, i started my car and it started working. May have been a bad connection in the bulb. We'll see if it lasts.
Old 01-08-2004 | 01:52 AM
JDMxB's Avatar
Originally Posted by doctorcue
The problem with warming up a car is that people let the engine get to operating temperature then take off like they have been driving for 20 minutes. I heard a while back on a car show is to just start the car, drive easily allowing all components of the car warm up together (engine, tranny, suspension, axles, etc.). This way, you can prevent unnecessary stress on the car.
I would say though, most people let their car warm up so the heater is blowing nice & toasty on them.
JDMxB, how is warming up your engine bad (other than what I mentioned)? Isn't that like saying idling at a stoplight on cold mornings damages your engine too? I not trying to be a dick, I just want to know what you have heard. Thx!
At a stoplight is fine--just unneccessary times and especially upon first starting the car. If you have intentions of just letting the car sit and idle with no reason--that's bad.
Old 01-08-2004 | 01:55 AM
JDMxB's Avatar
Originally Posted by mach5
:roll:
oh no, all the techs must be destroying you cars, its a big plan :shock:
Hey buddy--no need to be a smartass-not all of us are "CERTIFIED TECH's".
Here's a thought--how often do you do inspections, or change tranny fluid? I hope not as often as everyday when you drive the car. That's what we I was refering to. No ____, leaving it to idle once in awhile to do maint. is no big deal, but if you do it every single freakin morning--it would pose a problem.
Do what you guys want with your cars--but first read the instruction manual that came with it.
Old 01-08-2004 | 03:00 AM
yanges's Avatar
Originally Posted by randode
Originally Posted by bambbrose
plus the oil in the tranny needs to warm up a bit before driving as well
if you have a manual trans its not going to warm up unless you are driving since the clutch disengages the engine from the trans.
i agree with that! i warm mine up for 2-3 minutes and when i start driving, it is a little stiff to shift....after about 5 minutes or so, it is shifting smooth as butter....
Old 01-08-2004 | 03:27 AM
SGVside's Avatar
Just drive it like a normal car. Its basically the same thing.
Old 01-08-2004 | 05:59 AM
Kikaida's Avatar
Had my XB for bout a month now and I must admit, I was one of those who sat there in the morning til the thing went away. Took a good 5 minutes, but I didn't mind... That was 5 more minutes in the box! I've since taken the advice of the all knowing forum and drive it normal...keeping the rpm's low!
Old 01-08-2004 | 07:58 AM
UrbanDrum's Avatar
I stopped that habit too. Thanks to this forum I even safe money on fuel now because not only did I stop using 91 octane(@ CA prices) , I don't waste 5-10 minutes of gas in the mornings anymore either. Thanks guys...
Old 01-08-2004 | 08:14 AM
Kikaida's Avatar
Yup, me too... Went from 89 to 87! thx... Forum doesn't take a percentage of the savings do they?
Old 01-08-2004 | 09:13 AM
UrbanDrum's Avatar
Percentage would probably be nice...I'm sure it's not cheap the run a site like this...I hope it pays off with the shop and banners.
Old 01-08-2004 | 01:26 PM
CBSIMONSEZ's Avatar
The blue light indicates that the engine is still cool, and that heat will be there shortly. As far as letting your car idle when cold out, the jurry will for ever be out on that issue. Some say yes, others no. My theory, i let the car warm up if it is more then a couple of years old, or has a decent amount of miles on it 25K+. But, warm up is not more then a couple of minutes, just to get the juices flowing.
A car sitting idle in Park is not the same as sitting idle in traffic or at a stop light in Drive. In drive, you are still putting a load on the engine, which is why the rpms are different then when you are idling in your dirve way.
Old 01-08-2004 | 04:54 PM
Itsdchz's Avatar
OK.
FIRST:
If anyone thinks it is ok for you to start your car cold, and immediately drive off. KEEP DOING it MORON. Starting your car cold, and immediately driving it prodices the WORST wear on an engine. It takes 30 seconds- 1 FULL minute minimum for ALL the oil to reach every part it can lubricate. By driving immediately on those unlubricated parts, you a prematurely wearing components. Granted it may not be wear that is harmful once or twice, but I watch people all day long start their car and immediately drive it after it has been sitting outside for a day or two or even one night. Do you think your internal engine components feel good sliding metal to metal with oil between it, or with no oil? Do THIS TEST:
get 2 butter knives rub them together, now get the same 2 knives, coat them in motor oil. Which sounds better? which moves better? which one do you think after 40K miles of use will be in better shape?
Second:
I have been involved in MANY DYNO runs on many vehicles. We have done octane challenges, and believe it or not HIGHER Octane DOES boost engine performance. I have done Dyno Runs with 89, 92, and 100, 104 octane. The car is noticeably more responsive with higher octane AND the dyno numbers improved ever so slightly, BUT, after multiple runs and heat soak, the higher octane runs still held their HP.
Granted on today's modern technology maybe their isnt a difference between 87 and 89 octane. But no matter what I always use 91. From my 1990 VW with 215,000 miles on the original block, Mobil 1 oil, 91 octane, AND I warm it for at least 2 minutes every day. I do the same thing on my wife's 1992 Jetta and our 2003 Audi. Call me dumb, but the added security "just in case" is worth it to me, especially if it will promote longevity of my vehicles..
Old 01-08-2004 | 05:47 PM
Kikaida's Avatar
Whoa... why so serious . I actually don't start driving off right away in the mornings. Have to have that CHILL time in the box (look through the CD's, etc)...Thanks for the insight though. I'll probably continue to use 87 octane with about a 1-2 minute warm up.
Old 01-08-2004 | 05:50 PM
yanges's Avatar
hey Kikaida
Great Avatar :mrgreen:
Old 01-08-2004 | 06:46 PM
Itsdchz's Avatar
NAHHHH sorry for sounding so serious, I just want people to know whats up, and add long life to their Scions.
Old 01-08-2004 | 06:50 PM
Kikaida's Avatar
hey Kikaida
Cool THX! Half Man/Half Machine = Kikaida! Dig the Polar Box!
Old 01-08-2004 | 06:51 PM
Kikaida's Avatar
No prob... Can never have too much info! That way, peeps can make up their minds after consuming all the data.
Quick Reply: Blue temp light
