CIG fuse replacement
So, theres 2 cig lighters in the tC. 1 on the outside and one on the inside of the middle compartment. The one on the inside doesn't work for me and I just bought a fuse to replace it. But when I look at the fuse panel, I only see 1 of the fuses that says CIG on it...is that not the right now? I'm thinking that if there is only 1 fuse that works for both cig lighters, then both of my cig lighters shouldn't be working, but one of them does...how do I find out if the cig lighter in the middle compartment is labeled differently?
toyota....dealer? hmm....that sounds expensive... theres spare fuses in the panel under the hood...but no 7.5s in there =[
you know what else was in there? a fuse removing tool!! D: I tried pulling it out with my fingers then got frustrated so I took out a flat head screw driver to kinda gauge it out...now its a bit scratched around that fuse. I put it the fuse back in cuz it looks fine and now its slightly loose on the side I used the screw driver on...
Did your guy's acc cig lighter(the one in the middle compartment) work straight out from the dealer? The sales person I talked to said sometimes they leave it unplugged on purpose and that could be why it doesn't work. I bought the car used from someone...
