Dip Stick
Old 10-16-2004, 06:36 AM
DeliriousVisions's Avatar
Default Dip Stick
ummm.....whats with the plastic dip stick................are we the only cars that have a COMPLETELY PLASTIC dip stick? wtf?
DeliriousVisions is offline
Old 10-16-2004, 12:53 PM
OhioScions
ScionLawyer's Avatar
Plastic...metal....does it really matter? Both tell you when you need oil. LOL
ScionLawyer is offline
Old 10-16-2004, 02:31 PM
Rogo's Avatar
I agree - yellow plastic dipstick - why yellow, oil is yellow - makes it hard to read.
Would be nice if a chrome (or just metal) dipstick were availible.
Rogo is offline
Old 10-16-2004, 02:44 PM
jct
jct's Avatar
i like yellow i think it makes it easier to read and real ppl just uses there fingers to tell if the oil is still clean or not ;)
jct is offline
Old 02-01-2005, 05:03 PM
Jesboyhere's Avatar
Default plastic dipstick
after a long period of time the plastic dipstic will crack and will go in to the crankcase and will screw up your engine. they should have put a metal on in there un the first place
Jesboyhere is offline
Old 02-01-2005, 05:23 PM
Guest
Guest
Posts: n/a
Default Re: plastic dipstick
Maybe after 50 or so years
Old 02-01-2005, 05:30 PM
TheScionicMan's Avatar
Um, yeah, there's been a few advancements in plastic over the last 50 years. It's yellow so it's easy to find the handle, color coded to tell it apart from the tranny fluid, if equipped with auto.
When's the last time you had a dipstick problem? heard of someone with a dipstick problem? Only one I've ever seen was old metal ones that were rusty or metal/plastic ones that the handle breaks loose...
Are you looking at other cars to see what they are using? Do you really think Toyota would put something in there that they think will cause a problem?
TheScionicMan is offline
Old 02-01-2005, 10:19 PM
mach5's Avatar
plastic is a great cheap alternative
mach5 is offline
Old 02-02-2005, 02:16 AM
SRD_xB's Avatar
plastic = lightweight, duh
SRD_xB is offline
Old 02-02-2005, 02:32 AM
So, how much weight savings are you gonna get between a metal and a plastic dipstick? Pocket change would offset that...
Do you guys realize how many different varieties of plastic there are? By manipulating it, they can give it all sorts of properties.
Take UHMWPE, for example. That will be harder and last longer than some metals. I doubt they used the same formula that they use for coke bottles or beach toys...
Old 02-02-2005, 02:35 AM
Icecream_Truck's Avatar
Since when has engine oil been yellow. It's a clear light brown then as time goes on it turns to a dark brown maybe black.
Icecream_Truck is offline
Old 02-02-2005, 02:36 AM
SRD_xB's Avatar
i was joking about the lightweight issue...
SRD_xB is offline
Old 02-02-2005, 02:45 AM
pkoule's Avatar
Don't let your oil turnn black. Change it early and often.
pkoule is offline
Old 02-02-2005, 02:50 AM
i'm just saying that it is not yellow any time while in the engine.
Old 02-02-2005, 03:41 AM
RacerxB's Avatar
plastic=lightweight + low cost=low sticker price. Isn't this the reason we purchased the car?
RacerxB is offline
Old 02-02-2005, 12:32 PM
DeepSouth Scions
Ashe_WCM's Avatar
I always thought motor Oil was a nice golden color.
Ashe_WCM is offline
Old 02-02-2005, 01:40 PM
jct
jct's Avatar
golden brown color like honey, unless you use hydro oil in an oil change which is clear :oops: i did that to a few things at work
jct is offline
Old 02-02-2005, 10:11 PM
mach5's Avatar
yes toyota just threw in a plastic dipstick and didn't think about the future........
mach5 is offline
Old 02-03-2005, 03:14 AM
lol....i wasn't expecting to get this big of a response....anybody know where i can get a REAL DIP stick.....my buddies at jiffy lube laugh at me
Old 02-03-2005, 07:03 AM
Otocan's Avatar
you can go to somewhere and have them engrave the letters *T R D * in bottom of the dipstick where it measures the oil over and over again so it's easier to see where the oil goes up to because of the indents and everybody at jiffy lube will be like "OMG DUDE YOUR CAR CAME STOCK WITH A TRD DIPSTICK!!! OMG OMG OMG!!1111111"
Otocan is offline
Quick Reply: Dip Stick
