DIY: MAF/AIS cleaning
Old 04-08-2009 | 11:04 PM
HeathenBrewing's Avatar
Default DIY: MAF/AIS cleaning
Here is a DIY I did a while back and am just now getting a chance to post it.
I do this once a year in order to maintain the MAF. When cleaning by certain not to directly touch the MAF wire or the AIS. Both are delicate and expensive to replace. Total time is 15 minutes or less.
Tools :
First, remove neg. cable from battery:
Locate your MAF sensor:
To remove MAF assembly, first disconnect wires by pushing down on clip, then pull towards passenger side:
Use a Philips head to remove it from intake tube:
Remove MAF by puilling straight up and out:
Blurry pic of MAF/AIS assembly. AIS is on the left side of the unit:
Using your CRC MAF cleaner, spray down the AIS and the MAF sensor. The MAF sensor is located up inside the assembly:
Let dry for 5 minutes or so, then reassemble and enjoy a homebrew for your hard work:
Old 04-08-2009 | 11:10 PM
jct's Avatar
jct
i do mine every 5K miles, it just gives me some thing to do its quick and easy
Old 07-14-2009 | 03:57 AM
ecko04's Avatar
BUMP.....DO EEEETTT
Old 07-14-2009 | 04:22 AM
Coolwaterz's Avatar
how often should i clean it?
Old 07-14-2009 | 07:42 AM
dbl tap!
Old 07-14-2009 | 07:48 AM
EVERYONE will give you a different answer. This is the internet afterall....
Some say every 3K although I dont think it needs to be cleaned that often. Some say that it never needs to be cleaned (usually the same people who think transmission fluid lasts for the life of the vehicle ).
I fall somewhere in between those two extremes. I clean it everytime I change the air filter, which for me is every 12 months. Maybe it doesnt have to be done that often but since I am already there doing the filter, I figure why not do the MAF/AIS then. Makes it easy to remember to do it.
The can of CRC will last AT LEAST 15 years if you clean 1x/ yr. You dont need much of the cleaner to do the job.
CRC is cheap (< $5). MAFs are not ($125 and up).
Really, its up to you. Just clean it.
Cheers!
Old 07-14-2009 | 03:32 PM
ecko04's Avatar
MAF's are about $90.
You want to clean it before you throw the P0101 code
Old 07-30-2009 | 04:53 PM
kuo34's Avatar
I used carburetor cleaner, but results were the same. Quick, easy thing to do and gives you an excuse to look under the hood.
Also note that you will throw a CEL if you don't reconnect the MAF to the harness. Took me a minute to figure out what was wrong
Old 07-30-2009 | 05:07 PM
jct's Avatar
jct
my car just didn't run with it connected
Old 08-20-2009 | 10:58 PM
1epoXyBox's Avatar
Bump. Dealer recommended this needs to be done. Now I can do it myself thanks to this thread.
They also recommend Throttle Body and EFI to be cleaned. Not to sure on those.
Thanks
Old 09-16-2009 | 01:29 PM
XPRESSCION's Avatar
Thanks
I heard to use a toothbrush for throttle body. Gets in there quite easily and brush off. I was supposed to get mine done sometime but I kind of blew it. The guy who was supposed to show me, we're not on good grounds anymore.
Old 09-16-2009 | 03:56 PM
jct's Avatar
jct
just unbolt the throttle body and take it apart to clean it... its just a some bolts and few screws
Old 09-19-2009 | 10:03 PM
1epoXyBox's Avatar
I was going to do it this weekend, but now going to hold off until I'm ready for an oil change. I was reading some other sites where they said that the Throttle Body Cleaner's residue can actually mix with oil and break down the viscosity. It seems plausible, so I will do it right before the next oil change.
Old 09-19-2009 | 11:09 PM
jct's Avatar
jct
thats the same way with brake clean too... but they do make great hand cleaner... which dries 'em out afterwards...
Old 02-10-2012 | 04:46 PM
douglasinct's Avatar
Thank you so much for posting this DYI project.
I am starting to feel like an amateur mechanic.
Old 03-19-2012 | 06:26 PM
t_C's Avatar
t_C
Wink
I must have missed a step or two....
Could you elaborate on the DIY because no matter how many times I cleaned my MAF I still didn't get a homebrew IPA out of it.
Thanks.
Old 03-20-2012 | 12:32 AM
burstaneurysm's Avatar
If you need help getting rid of homebrew IPA, I can totally help you out.
sciontc008
Scion tC 1G Aero & Exterior
01-20-2016 06:10 PM
ScionDP
Scion tC 2G ICE & Interior
11-05-2015 10:59 AM
Luisfc1972
09-30-2015 01:22 PM
excessads
09-15-2015 06:28 PM
paisatronix
09-05-2015 05:13 AM
