Does Synthetic Oil really improve mileage?
I am debating whether to use it or not. I don't think I'd like leaving even pure synthetic in my engine for over 6K because engine contaminants still accumilate even if the oil isn't breaking down.
If any of you have noticed any signifigant improvements by using synthetic please share your experiences.
Re: Does Synthetic Oil really improve mileage?
If you are changing your oil every 5-6k you should stop. Well, this is my opinion but i have found my motor(s) for previous car and this car runs a lot better when changed every 3k. If it does improve gas milage, i have yet to see any improvements. Synthetic oil stays cleaner longer, and helps performing motors keep performing they way they should. (hints why most sports cars come with synthetic oil from the factory)
Its up to you, so good luck either way.
Cya
i all depends on your budget... like it was posted above.. syth really does nothing for you in the way of performance and even gas milage (depending on who you believe and what you read).. but does help longevity of the engine (proven).. especially seals.. you will get varing arguments as to when you should switch or not... i have had syth in the tc engine from the 1000 mile mark.. with absolutly no problems.. started with mobil 1... and this last oil change i switch to royal purple seeing it was only 60 cents more then mobil 1.. i change the oil at around 4000-4500 mile intervals.. does it get expensive..? sure does.. is it worth it..? IMO.. sure is......
having said all that... if you plan on changing your oil regularly.. say 3500 to 4000 mile intervals.. i see no reason, if you use a good quality conventional oil your engine should not be just fine..
Originally Posted by dsilverstreak
synthetic oil will do NOTHING for performance or mileage and will only help longevity when you start thinking about over 200k miles capability.
Of course, 1nz or 2az (scions) are not performance-tuned however, as i stated above its pointless with a stock motor. f/i people especially, i would recommend synthetic oil for the added protection for the overall motor.
Everybody has their own thoughts and opinions on what synthetic can do for a motor, and i respect anyones opinion. I'm just stating mine with experience of personal, and friends. Plus with a few facts included.
Same with tranny oil. Lots of people say that synthetic tranny oil does absolutely nothing. In reality, if you have a built motor it helps keep temp. down, and improves shifts. Especially on automatics. Added whp (not talking about ten) increases inner-tranny temp. and obviously, it works harder. Same concept with a motor, the more built a motor is (especially smaller motors like the 1nz) the harder the motor works. Thats pretty obvious. Synthetic motor oil adds a little more protection, runs a little cleaner and overall is better for a built motor (again, especially smaller motors) vs. regular oil.
Cya
i used to drive a 88 honda accord wich was CARBURATED used castrol syntec on it and the milage went up from 27miles/gallon to 32miles /gallon driving 99% hwy . On the box i have been using mobile 1 every 3000 miles and the milage has not improved at all. Funny that the old car got better miles than my my so called econobox which only gets 28/gallon.
Cya
Originally Posted by shangtsung
Originally Posted by killerxromances
Good point. Youre either 100% in synthetic or 100% not.
Cya
Cya
Laterz
Cya
I recently switched to Royal Purple oil + man trans fluid.
Gas mileage is unchanged - I check on every fill up.
There seems to be a bit of a HP increase. Easier & quicker revving.
That's my "seat of the pants" dyno report.
I agree that blends make no sense. Use 100% synthetic or standard oil.
Originally Posted by Totemobakadesu
Not improve it..I think it is all mental...however the engine does feel smoother......maybe it is just me. I used mobile 1 after 1500 miles
I also use mobil 1, i have now for the past 13,000 miles. (started around 5,000 miles)
Cya
Geez lots of opinions here....little accuracy
only a few oils are true pao synthetics....Mobil 1, Redline, Royal Purple, Amsoil, and German made Syntec 0W30
for accuracy look here
http://bobistheoilguy.com/
Cya
