Hammering the gas during break-in period
Old 07-16-2005 | 09:40 PM
AzurePearlTC's Avatar
Default Hammering the gas during break-in period
Ah ____. I messed up my car. Ok, not really, but I'm still driving during the break-in period, and I already accidentally stomped on the gas and made the engine rise up 5k+ RPMs in a split second. I accidentally did that two times in one day within an hour. Damn....
I couldn't help it because I was about to drive through a yellow light and I couldn't decide to make a hard stop or just run it when it turns red, so at the last minute I stomped on the gas and made it past the intersection. And unfortunately, I did this twice and I only have like 370 miles on it. Have this happened to anyone?
What foreseeable damage have I caused to my engine? What I'm most worried about is getting poor gas mileage later on.
Old 07-16-2005 | 09:42 PM
ScottyeyttocS's Avatar
Don't worry about it. It's prolly better to rev your car up once in a while during the break in period then not to.
As long as it's not a habit u shouldn't have any problems.
Spif's Avatar
I wouldn't sweat it. If you are so worried that you did this twice, you probably are not going to be doing it consistantly, which is what would likely actually damage your car in the long run. Just be nice to your car and try and keep that tach below 5k most of the time and your engine will be fine.
Old 07-16-2005 | 09:45 PM
teksno's Avatar
im going through my break in now as well... dont worry as long as you dont do it alot... youl be fine.
Old 07-16-2005 | 09:54 PM
StarsplasH's Avatar
im almost to 1000k miles and ive revved it high occasionally...its okay just as long u dont floor it every single time
Old 07-16-2005 | 09:57 PM
dmikon's Avatar
It's all good. Your engine won't fail any time soon.
Old 07-16-2005 | 09:58 PM
dmikon's Avatar
Wow, you've reached a million miles? That has to be some sort of record.
Old 07-17-2005 | 04:45 AM
scion_tC's Avatar
i did that once, only on purpose i was passing this car and I hit the gas and to my surprise the car took itself all the way to 5.6K before shifting, i didn't care b/c it's not such a bad thing that the engine gets to experience upper end power during break in, not much but a tad bit...i was probably at 5600 for 15-20 seconds, then back to normal.
Old 07-17-2005 | 11:54 AM
rabberflatch's Avatar
i actually heard its good to push your engine during break in to seat ur piston rings nicely (motoman theory hehe). thats controversial however it does make some sense. u should be safe. what i do is drive conservatively and every once in a while get the revs pretty high, kinda like mixing both break-in theories. i figured taking the middle road should be safe haha
Old 07-17-2005 | 02:40 PM
06tCguy's Avatar
I'm probably gonna drive it normal, and not baby it. That's what my buddies do when they build motors. And toyota engines, and most other engines, are run on an engine dyno at the factory for a period of time.
Old 07-17-2005 | 07:58 PM
Doglass's Avatar
You haven't done ANYTHING...sheesh.
Old 07-17-2005 | 08:42 PM
xxDOOBIExx's Avatar
the motor is broke in at the factory. the high rpm's are fine as long as you keep it out of the redline.
Old 07-18-2005 | 03:40 AM
farberio's Avatar
Break in period for our motors = 10 miles.
The 1K break in period is for GM motors because they are built looser then the tC motors.
Breaking in means not to keep the engine at one RPM for a long time. So vary your speed.
yupinmytC
22
07-27-2024 08:08 PM
TotalChaos
01-22-2016 12:27 AM
BlingSlade
11-20-2015 07:56 PM
user9430961
09-15-2015 04:16 AM
StxArOne
Scion xA Aero & Exterior
08-21-2015 07:44 PM
