how do i remove sprayed on tint
Old 02-14-2008 | 10:11 PM
jct's Avatar
jct
denatured alcohol FTMFW!!!
before
after
i used 3 micro fiber towels to clean 'em off, one towel to remove the tint with the denatured alcohol, another towel to pre-clean it with the denatured alcohol, 3rd towel to give it a final clean job with the denatured alcohol...
and after that i washed it up with some car soap, dried it, polished it, and waxed it...
you'll also want to use rubber gloves, don't want to dry your hands out...
Old 02-15-2008 | 05:51 PM
bigwillystyle23's Avatar
denatured alcohol FTW
Old 02-15-2008 | 06:15 PM
pudgy1's Avatar
nice this is actually a pretty useful topic
Old 02-15-2008 | 07:53 PM
vettereddie's Avatar
Possibly paint thinner, test first to make sure it won't damage the plastic, and uninstall your tails to do this so you don't het it on the car's paint. You could try airctaft paint stripper, it's even at Walmart, but again, test first. it leaves paint like goop that then needs to be wiped off and will DEFINATELY take off your automotive paint, so would again need to de-install the tails to use it.
Old 02-16-2008 | 01:21 AM
jct's Avatar
jct
thats why i don't really trust paint thinners on clear plastic parts you don't know what your gonna get with the results :?
Old 02-23-2008 | 05:04 PM
yellowxhoodie's Avatar
ive done this before.
just wetsand it all off with a higher grit, then move down to a lower grit to smooth it out a little but still keep a little grit, then spray some clear coat on it. looks brand new.
Old 02-23-2008 | 09:33 PM
jct's Avatar
jct
sanding takes forever the way i did it took my at most 10 minutes to clean both headlights
Old 02-23-2008 | 09:35 PM
yea but like you said earlier you dont trust paint thinners...i didnt want to take any chemicals to the lights and possibly get some on the cars paint and F it up.
lookinforlinks
04-06-2015 06:57 PM
CPL_Radar
03-05-2015 05:42 AM
Opr8r
100
09-21-2009 06:29 PM
Opr8r
20
02-25-2004 11:29 PM
Quick Reply: how do i remove sprayed on tint
