I got a check engine & vsc lights on. can anyone help???
Old 08-08-2005 | 05:00 AM
SEM170's Avatar
Default I got a check engine & vsc lights on. can anyone help???
yesturday i did my second oil change on my xb and everything was fine: i added some neon lighting under my hood a few hours later and when i started my car the check engine and vsc lights came on. i notice slight stalling when in park and i was wondering if anyone out there may have experianced something similar. if so i would appriciate a any sugestions or tips.
Old 08-09-2005 | 01:53 AM
toastbox's Avatar
honestly, why not take it to the dealer? clearly it's throwing the lights for a reason, the dealer can tell you all of that. If it's underwarranty, they won't even charge you for it.
Old 08-10-2005 | 01:24 AM
xmetalx's Avatar
Default Re: I got a check engine & vsc lights on. can anyone hel
you know, i just did an oil change about 500 miles ago, and i just noticed my maint required light turned on, and the car comes close to stalling in idle as well.
Old 08-10-2005 | 06:39 AM
SEM170's Avatar
i did not want to take the car to the dealer because i changed the stock air box for a cold air intake and that would void my warranty. i had the car checked out today at a friend's shop and the problem was the mass air-flow sensor that mounts on the intake. the part is $150 from toyota so iam going to go back to the stock intake (temporary) so that i can get the car serviced at the dealer.
Old 08-10-2005 | 08:08 AM
xmetalx's Avatar
i was looking at mine as wellm the little sensor thing that hangs down looks to be all cloudy and stuff, i tried changing it, also i do oil changes myself, not sure if the scion cars have a built in deal that needs to be reset everytime you get an oilchange to alert the driver incase he or she hasnt got one in a while?
Old 08-10-2005 | 01:37 PM
toastbox's Avatar
Neither a CAI or SRI will void your warranty. It's called the Magnussen-Moss act. Do a search for it on this site, you'll find more posts than you can stand to read.
Jordly221
02-13-2019 05:29 PM
Miqmiqmiq
04-16-2016 02:34 AM
daniinpitt
04-04-2015 08:07 PM
AdmirN
01-05-2015 10:19 PM
ScionRo
01-02-2015 07:54 PM
Quick Reply: I got a check engine & vsc lights on. can anyone help???
