Irregular dipstick reading need advice
Ok you guys this actually has to do with my Tacoma.
When I check the oil one side of the dipstick looks WAY high, but the other side is just at the right level. Why am I getting 2 different readings on my dipstick and which one should I follow?
And yes the vehicle is parked on level ground etc etc.
Thanks everyone.
Thanks everyone.
my moms truck does that too... S10. But her oil fill and dipstick are in the same hole. so oil running down the tube sticks to the sidewall of the tube. Possibly the same in your case. even if the fill and dipstick are in different places, driving can cause the oil to move around and stick to things.
Just a possibilty
Just a possibilty
Originally Posted by duck_dodgers_24_5
sounds like the dip stick is going at an angle to the oil pan go with the side thats is at the correct fluid level
it will be fine, if your worried about it give it an oil change with the correct amount of quarts of oil
06ScionTc5sp1
9
10-16-2020 01:18 AM
