Jiffy Lube Oil Change
Old 03-22-2004 | 06:40 PM
XBman's Avatar
Default Jiffy Lube Oil Change
Hey all,
I went to the jiffy lube to get my oil changed ( 2700 Miles) on monday and i got a terriffic deal. $15 out the door with an oil change, and they included a free air freshener. If i have wanted to they would have flushed my radiator and changed my oil for $25!!! this is a terriffic deal, and the guy told me that this deal is going on at all southern cal jiffy lube's ( im not sure thats true) but anyways i would highky recommend them. It took about 1 hr and it was done!!!!! :D
Old 03-22-2004 | 06:47 PM
yanges's Avatar
Default Re: Jiffy Lube Oil Change
Originally Posted by XBman
Hey all,
why would you go there when you get 3 free oil changes from Scion?
Old 03-22-2004 | 06:48 PM
XBman's Avatar
I dont want toyotas oil in my car...... also the free oil changes are at 5,000 miles :twisted:
Old 03-22-2004 | 06:57 PM
tbblizzard's Avatar
nah, i got mine done at 3400... it just says 5,000 cause that's your service intervals... they do a 19 point check and lube and what not besides the oil... you can bring it there whenever you need your oil changed, they don't care, they're gonna have to do it sooner or later.
Old 03-22-2004 | 07:01 PM
XBman's Avatar
Oh really dang oh well jiffy lube was still good
Old 03-22-2004 | 07:03 PM
yanges's Avatar
i got mine done @ 3193 miles.....you can go whenever you want....
and from what i understand, Jiffy uses Penzoil.....
Old 03-22-2004 | 07:18 PM
jonathan's Avatar
FYI, all 04' Toyotas and Scions have their radiators filled with a new super long-life antifreeze. It's a 50/50 mix and it's supposed to last 100,000 miles.
Old 03-22-2004 | 07:28 PM
NemoBronsky's Avatar
and if its anything like gm's dexcool extended life coolant that turns to mudd after about 30-40k miles I dont want it !!
Old 03-22-2004 | 07:38 PM
Djuan's Avatar
Default looks fine
well I have 30,000 miles on my xB and the coolant looks fine...
Old 03-22-2004 | 10:21 PM
XBman's Avatar
30,000 miles !!! man thats alot! when did u get it?
Old 03-22-2004 | 11:38 PM
TheScionicMan's Avatar
What kind of oil is Toyota using that could be worse than Pennzoil??? :?: :?: :?: This is the first I've heard of bad "Toyota oil", most shops carry a national brand in bulk...
When I used to work at a Jeep dealership, a customer came in that was missing a dipstick. She told us she had just gotten her oil changed at a jiffy/supr lube place. We called them and told them they better send someone down with her dipstick. 10 minutes later here comes the jip-me lube shop boy with a handful of dipsticks. The friggin' idiots did it more than once and they couldn't even tell which was hers... Our tech grabbed the right one and we just wondered about all those other cars out there ... You get what you pay for...
I'm guessing that two techs with equal experience and skills get offered a job EITHER at Toyota or Jiffy Lube, you're gonna find the most highly skilled ones changing oil...
Old 03-23-2004 | 09:48 AM
Djuan's Avatar
Default and running like new
I got mine about 8 months ago, almost 9...
Old 03-23-2004 | 10:45 AM
Cardinal_Fang's Avatar
I've learned, through a bunch of bad experiences, to always check my oil about a week after it's been changed---REGARDLESS of where I get it changed. I've found oil caps and/or dip sticks missing, and oil leaks around the oil filter or drain plug. I'd probably do this even if I changed the oil....because I know how absent-minded I am....
C.F.
Old 03-23-2004 | 08:41 PM
its_ikon's Avatar
toyota oil is a lot better then pennzoil. toyotas run for a long time for a reason and that is because toyota has good products.
Old 03-23-2004 | 09:05 PM
XBman's Avatar
I use Mobil 1 oil not Penzoil...... i had it requested
Old 03-23-2004 | 09:12 PM
George's Avatar
C.F.
A week? I open the hood and check it right in the dealer's driveway! A friend had his oil changed at the same dealer and they put in a total of 1.5 quarts, just enough for the engine to run without the oil light coming on. When he discovered this he had the car towed back to the shop and they said "oh, the dial on the dispenser must have slipped again!"
George
Old 03-23-2004 | 10:30 PM
George's Avatar
Toyota dealers do not use Toyota oil. In fact, I don't know if Toyota even markets its own brand of oil. Our dealer uses Quaker State oil, others probably use whatever oil is cheapest from the jobber.
If you're using petroleum oil then any brand is pretty much the same as they are all made to meet the current API specification.
Synthetic oil opens a new can of worms.
George
Old 03-25-2004 | 01:08 AM
Djuan's Avatar
Default uh oh
what can of worms would that be ? I have synthetic...
Old 03-25-2004 | 05:36 AM
rbloedow's Avatar
I read this thread and just rolled my eyes. There's a sucker born every minute, and you're one of them - falling into the clutches of oil companies and their false advertising. Go by what your manual says, not what the people who are selling you their products say (A little hint - they're int the business of selling their product, not protecting your car, so naturally they're going to try and get you to buy their products, and it seems as if you've fallin' for their advertising)
It's a total waste to change your oil that early, a waste of your money and good oil. If anything, you should be worried about what kind of crappy filter the crap hole (Jiffy Lube) used on your vehicle. Don't worry, they probably used a Fram, the worst filters on earth
Do yourself a favor and eliminate the middleman, change your oil yourself, don't let the nimrods at "Jiffy lube" even touch your car.
Old 03-25-2004 | 06:09 AM
George's Avatar
Default Re: uh oh
I should have said "religious argument"! Don't worry, your synthetic is fine as long as it meets the basic motor oils specifications in your owner's manual. Most any synthetic you buy off the shelf at your local FLAPS will meet that spec.
George
