"Maint Required" WTF! HELP!
Old 07-13-2007 | 08:15 AM
TurkishPrince's Avatar
Default "Maint Required" WTF! HELP!
I was driving home, and next thing u know, i look and see my "Maint Req" light is on? what could this be ffrom, i jus got my oil change a lil more than a month ago, and put about 1000 miles on it.......wat else would triiger this to come on? Thanks would appreciate any help!
Old 07-13-2007 | 08:19 AM
brian's Avatar
im guessing you just hit 5k miles? just reset it, there's no way the car can tell how new your oil is, the tech is supposed to reset it so obviously he didn't do that when he changed your oil.
Old 07-13-2007 | 08:20 AM
SquallLHeart's Avatar
^^ what he said.
it's just a mileage counter. read your owner's manual man.
Old 07-13-2007 | 08:25 AM
Are you guys sure? And how do u reset it, ive read the manual but i guess i dont rememebr that part.....so the maint req only has to do with the oil right?
Old 07-13-2007 | 08:27 AM
brian's Avatar
read squalls sig...the very first line.
Old 07-13-2007 | 08:32 AM
actually it really has to do only with your mileage.
used only as a reminder to change your oil... nothing really directly related other than that.
Old 07-23-2007 | 07:29 PM
KiKaZ-tC's Avatar
Maintenance light RESET:
Page. 96 of Scion tC 2006 Owners Manual
1. Turn the ignition key to the "OFF" position with the odometer reading shown.
2. Turn the ignition key to the "ON" position while holding down the trip meter reset ****.
Hold down the **** for at least 5 sec. the odometer inidicates "000000" and the light goes off.
Old 07-23-2007 | 08:31 PM
badbasic's Avatar
^^^^ wat he said. when u have the button pushed in and turn the key to on, u should see a series of dashes instead of numbers. the dashes will count down till u have the 00000
Old 07-28-2007 | 08:24 AM
bB2NER's Avatar
Music City Scions
It only seems hard the first time you have to do it. I wonder if that feature could be unhooked. I'm tired of having to keep resetting it every 3K or so. Especially seeing how I go 5K between oil changes.
Old 07-28-2007 | 08:27 AM
nytlemgr's Avatar
You can change it so the light will come on every 5k miles instead of 3k.
Old 07-28-2007 | 08:33 AM
bB2NER's Avatar
Music City Scions
I'm prolly gonna just cover that symbol with some black electrical tape next time I have that section apart.
I keep a maint. record for each vehicle so I don't need reminders.
Thanks for the info anyways so go and post it up how to change fron 3K to 5K anyways.
Old 07-28-2007 | 10:45 AM
nytlemgr's Avatar
Everything you need is in the very first posts (near the bottom): https://www.scionlife.com/forums/viewtopic.php?t=20749
Originally Posted by scionlife
Contributed by eric m.
After you've driven your Scion for a few thousand miles, you will see a "maintenance required" orange light flash for a few seconds in the center display console every time you start your car. Do not be alarmed. this is just a reminder to have your oil changed. If you change your own oil, you can reset the light. here is how:
1. Turn on the ignition and make sure it is on your odometer display, not the trip display.
2. Turn off your ignition. Hold down the trip meter reset button and turn the ignition on. Keep the button pushed in.
3. The maintenance required light will flash for a few seconds. when it turns off, let go of the reset button.
The the display will change for 1 second and go back to the mileage. That's it.
Contributed by Scott17
In case you didn't know and would like to use this function, when you hold the odometer reset **** and turn on the ignition, 5 bars in the odometer display flash and then sequentially go out. Each of these bars represents 1k miles. If you want to set the light to come on in 3k miles, let go of the reset **** with 2 bars remaining. 4k with 1 bar remaining and so on. Each bar that goes out will be 1k miles before the light comes on.
Old 07-28-2007 | 10:53 AM
bB2NER's Avatar
Music City Scions
Thanks for the info nytlemgr. It will help other I'm sure. Strange how I never heard that stuff before.
yupinmytC
22
07-27-2024 07:08 PM
BlingSlade
09-05-2015 08:52 AM
litobirdy
12-13-2004 08:00 AM
Diluvium
12-09-2004 03:45 PM
shinkuu
11-01-2004 07:11 AM
Quick Reply: "Maint Required" WTF! HELP!
