P0031 check engine light code
Anyone know what this code means, P0031 bank 1 sen1 heater circuit low
have read other check engine codes but this one is not so clear to me.
ANy help will be greatly appreciated, did a search and found nothing useful on this.
Thanks
Allen
Thanks
Allen
Take it to the dealer to have them diagnose/possibly replace the primary 02 sensor.... it's important to minimise driving with that code, as the primary o2 sensor performs a significant function with the engine....
It should be easily covered under warranty for you.
-WDS
-WDS
LoL.... you'll probably have to fork out the cash for a primary 02 then...
check the wiring first though, and ensure it's connected securely and completely.... you can then reset your ecu by disconnecting the negative lead and reconnecting it, and if it comes back, you still got a problem.
Re: P0031 check engine light code
Originally Posted by rrimportracer
Anyone know what this code means, P0031 bank 1 sen1 heater circuit low...
CIRCUIT LOW (BANK 1 SENSOR 1)
"The ECM provides a pulse width modulated control circuit to adjust current through the heater. The heated oxygen sensor heater circuit uses a relay on the B+ side of the circuit."
so the heater is somewhere around the sensor, its connected on the same circuit, nice schematic, not i have to find out where it is in my car, thanks for the schematic
DTC No. P0130
DTC Detection Condition
Output voltage of heated oxygen sensor remains at 0.4 V or
more, or 0.55 V or less, during idling after engine is warmed up
(2 trip detection logic)
Trouble Area
Open or short in heated oxygen sensor (bank 1 sensor 1)
circuit
Heated oxygen sensor (bank 1 sensor 1)
Heated oxygen sensor heater (bank 1 sensor 1)
EFI relay
Air induction system
Fuel pressure
PCV hose connection
PCV valve and hose
Injector
Gas leakage in exhaust system
ECM
Isnt the search button great? lol... I went boost about 3 months ago and just got this code. (P0031) Where exactly is the sensor located? on the exhaust mani towards the front of the car? underneath the car? is there another location? also, i was looking into 02 sensors,... which of these two links do you guys think would be the solution?
http://www2.partstrain.com/products/...4~TC--001.html
or
any help would be greatly appreciated. Thanks in advance
or
this problem is a tsb for 05 models, its something with the calibration of the primary o2 sensor, if your boosted, its the o2 sensor in the dp, try changing it out and see what happens
so is that in deed an o2 sensor? or an af sensor? reason im askin is cause ive heard it to cost anywhere from 150 to 180 which is the price of the af sensor above, but when i look at o2 sensors, they come out to 30 bux... just wanna clear up my confusion... thanks for the response rrim
So did you guys figure out how to fix this issue?
After we installed my turbo kit, I got the p0031 code.
I checked the vins on the TSB that was issues, and mine is a good 40,000 after the last listed. Do I just need a new 02 sensor? The one in the down pipe?
daniinpitt
04-04-2015 08:07 PM
rcflyer15
12-05-2014 05:15 PM
