Rear Hatch Door -- best way to close it
I know for some including myself, there's been concern that the only way to close the xB's rear hatch is to slam it shut. I've found that the xB is a fairly air-tight vehicle and the best way I've found to shut the rear hatch -- without thinking I'm damaging something -- is to leave one of the doors open, and as I'm shutting the hatch, just let it go when it's about 6"-8" from closing. The door's own weight gives it enough force to shut w/o me feeling like I'm slamming it closed. fwiw...
Re: Rear Hatch Door -- best way to close it
However, it seems that there is quite a bit of variation from vehicle to vehicle in how the rear hatch closes. Some are easy, some are hard.
George
mine will not shut easily if all other doors are shut, but with a side door or window open it will latch on its own by letting it drop like you mentioned....
the xB is fairly airtight and i think the size of the rear hatch makes it have to push a lot of air out of the way to close....
I first noticed this problem at the dealer on my first test drive. Even when I slammed the thing down, the light would stay on. What works best for me is to bring the hatch down about 2/3 of the way. Then, with my palm on the Scion logo, shut it down - firmly without slamming it. Works everytime!
I usually put my palm on the lower portion of the hatch...below the license plate closest to where the it will latch and give a firm shove to make the light go off. I'm almost positive that even if the rear is latched properly the light may still go on because the sensor is misaligned or something.
I have tried all the suggestions made in this forum since about 3months ago and I'm having a 50/50 chance or less. What definitely helps is opening a door but even doing that I still have to close it 3or 4 times. What I've been doing lately and seems to have a 75% success is opening a door and pushing on the left (driver side) corner of the hatch. Seems like different strokes for different cars but definitely there is a problem there.
Possibly leave your vents on the fresh air side rather than recirculate?
I was driving to work today with all the windows up and the doors locked. I pushed the air vent over to fresh air and the open door light came on?!?! I have to go to the dealership anyhow for a few things, why not one more.
webekyle
02-07-2015 07:15 AM
bluxb
12-02-2003 04:34 AM
