Routine Check-Ups Actually Needed?
Old 10-14-2005 | 07:52 AM
ScionxR's Avatar
Default Routine Check-Ups Actually Needed?
So my xA is just about 25K miles on it. And i have yet to do the reccomended 15K mile check up. Im noticing i used to get 35+ MPG and now i can barely get 300 miles per tank. Could this be due to lack of check up and possible low fluid levels, or loose belts? Also my xA is a manual that i drive harder than i should. I also switched from 15's to 18's but i doubt i would loose 10 MPG from it.
Old 10-14-2005 | 01:45 PM
dexter_5000's Avatar
did you get your transmission oil changed?
Old 10-15-2005 | 05:29 AM
ScionxR's Avatar
no. other than oil changes and adding a intake, exhaust, and some 18's, nothing else done.
Old 10-15-2005 | 05:33 AM
STAT's Avatar
you can loose a lot going from 15-18, heveyer bigger harder to spin. and I think he was asking if you changed your oil like in a regular check up wise, not as in a performance wise.
Old 10-15-2005 | 06:29 AM
ScionxR's Avatar
no trans oil changes. Is it something that would affect mileage and can is it easy to flush and fill as a DIY project?
Old 10-15-2005 | 11:24 AM
its part of the recommendended maintance for your manual transmission. the larger wheels will cause a drop in gas mileage though.
my06tc
06-25-2015 12:18 AM
debris
03-13-2015 08:15 AM
rancur3p1c
12-19-2014 04:30 PM
XB_2
11-23-2014 02:48 PM
SCI_FIRE
01-04-2004 06:45 PM
Quick Reply: Routine Check-Ups Actually Needed?
