Sometimes hard to put into 1st gear
Old 11-22-2004 | 05:17 AM
BeQuietAndDrive's Avatar
Default Sometimes hard to put into 1st gear
Does anyone eve have the problem where sometimes, it's a little hard to put into first gear? Like, it has to be coaxed to go in? Mine does this sometimes.
Old 11-22-2004 | 07:22 AM
UnFocused's Avatar
Its compleatly normal...When its cold, it will always be difficult. when i warms up after 10 or so minutes, it should be easier to get into gear...
Old 11-22-2004 | 08:59 AM
hotbox05's Avatar
alot of cars are slightly hard to put back into first
Old 11-22-2004 | 10:59 AM
SWF_05_tC's Avatar
First gear is generally not synchronized, the same with reverse. They do this so that you don't accidentally downshift to first, or shift into reverse while moving forward. It is completely normal.
Old 11-22-2004 | 02:21 PM
Ah,gotcha. Thanks a lot.
I really hate the 1-2 shift though. Wish I could do something about it. It seems much longer than all the rest,haha.
Old 11-22-2004 | 02:28 PM
Munch's Avatar
Get a short shifter
Old 11-22-2004 | 06:18 PM
bBted's Avatar
i have TRD short shifter....feels lot better
Old 11-22-2004 | 09:44 PM
Does the short shifter make it too short? It seems like I would have to reach down the if the sihifter were much lower, haha.
Old 11-23-2004 | 01:32 AM
Sciond's Avatar
Here is how to avoid diificulty. Shift into reverse first then go to first gear it will then slide right into gear
Old 11-24-2004 | 05:27 PM
fireballfish's Avatar
the reason this works ^^^ is because in order to get from reverse to first, you have to go through neutral. if you need to do a 2-1 shift, double clutch, in that you let the clutch out in neutral before putting it into first... easiest way to do a 2-1 shift
Old 11-24-2004 | 06:23 PM
hotbox05's Avatar
for the xa/xb the short throw shifter is only about .75 inch shorter in overall height
Old 11-24-2004 | 10:00 PM
Sciond's Avatar
true I forgot to add that.........either way works :D
Old 11-24-2004 | 10:34 PM
Sciond's Avatar
oops
Old 11-26-2004 | 07:20 PM
4rjn's Avatar
yep mine is the same way it must be warm.
evolving_machine
10-21-2023 02:16 PM
evolving_machine
01-13-2015 09:04 PM
baker08tc
12-30-2014 01:02 AM
gularti
12-04-2014 02:21 PM
iglooxb
15
07-25-2004 07:18 AM
