Voiding the warranty
Old 07-28-2005 | 07:31 PM
Nate2085's Avatar
Scion Dynasty
Default Voiding the warranty
I appologize if this is in the wrong section. If so, please move it. Thanks
What can I do to my tC without voiding the warranty? I've been looking into the sway bars, TRD lowering springs, TYC tail lights, and some new rims. I think it's cheaper to do all this myself rather than take it to the dealer and let them do it. So, how far is too far when it comes to modifications?
Old 07-28-2005 | 07:42 PM
maximus96's Avatar
you can do anything to the tc w/o voiding the warranty. its been discussed before. but they can only refuse to fix a part if its been determined that an aftermarket part has caused the problem. but they can't void your warranty entirely. somebody correct me if i'm wrong
ScionDad's Avatar
All that you listed will not void your warranty....unless for example, you put the struts on, they fall off and destroy your suspension. Then, it would not be covered under warranty. The aftermarket product must be the reason for the damage to void the warranty.
Old 07-28-2005 | 07:44 PM
Nate2085's Avatar
Scion Dynasty
Righto. That makes sence. Thank you for the replies!
Old 07-28-2005 | 08:02 PM
rivrtc's Avatar
If you stick with the recommended TRD upgrades and the dealer installs them they will actually be included with your OEM warranty, and extended if you have one. I was able to find out a couple of weeks ago that even the supercharger from TRD is going to be covered under the powertrain warranty, 5 yr 60K, pretty good deal, but that only applies if the dealer does the install.
One thing I will tell you that will void your warranty is splicing into the main wiring loom that runs through the entire engine, if you are going to do light mods like HID, wire the HID into the factory wiring harnes housing and clip that into the main loom... no harm done. The TYC lights should alrealy have a factory wiring harnes to match the Toyota, so you should be good to go there too.
Old 07-28-2005 | 08:23 PM
matchbox's Avatar
Default service techs
Make sure you get in good with a service tech from your Scion dealership. It might come in handy one day.
Old 07-28-2005 | 08:32 PM
jboogz's Avatar
The only thing i know for sure that voids your warranty is a turbo & thats only the engine /powertrain part or if you put on a c.a.i. then hydro lock the motor. Other than that you're pretty safe because there's a law somewhere that says a dealer can't void your warranty because of something you put on your car unless they can prove the the part installed caused whatever damage is in question!! Sorry for getting technical. Just my loose change.
tsullivan03 is right anything trd is covered under warranty.
Old 07-28-2005 | 09:25 PM
05-RS1's Avatar
jus to clear things up, anything trd that the dealer installs for u is under warranty
Old 07-28-2005 | 09:31 PM
maximus96's Avatar
how does the dealer know whether or not the trd parts were installed at a dealer vs. buying online and installing yourself? do they note that in their computer or something?
Old 08-02-2005 | 07:47 AM
Dat_Dude's Avatar
Any part added that is not officially designed for that particular vehicle and in turn causes extensive damage to the vehicle will void warranty.
Old 08-02-2005 | 12:51 PM
raWr215's Avatar
ditton on dat
but if it's minor mods(cai, shocks, exhaust) as long as they install it for u, it will not void warrenty. if you install it your self and screw up, then that's on ur ___. IF u successfully put on a mod and has no problems, then it will not void warrenty
Old 08-07-2005 | 11:26 AM
tC_kevin's Avatar
someone please answer this
Old 08-07-2005 | 01:30 PM
wingsaseagles's Avatar
ScionERA
Default Warranty
There is a law on the books called the Manuson Furgeson act it is a federal law that has to do with implied warranties .....
If you put on accessories IE: TRD approved parts the company CAN NOT void your warranty.........................
However if you hdrolock your motor as stated above you are #%^&*$* a turbo or supercharger would void the powertrain warranty but the rest of thewarranty must stay intact.
Also if you submerge a vehicle it not only voids the warranty but it must be re-registered as a salvage titled vehicle
wingsaseagles
Old 08-07-2005 | 02:05 PM
wylietc's Avatar
I have two giant goons escort me to the dealership. I've never had any warranty issues.
Old 08-07-2005 | 02:08 PM
ScionERA
Default warranty
I am a big giant goon , dont need no escort!!!!
BIG, UGLY, BALD, and Heavily TATTOOED
wings
Old 08-07-2005 | 11:24 PM
UnFocused's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=55338
the SEARCH button is your friend
yupinmytC
22
07-27-2024 07:08 PM
Sgtfluffy16
Regional - Northeast
07-28-2021 10:32 PM
Luisfc1972
Scion tC 1G Wheel & Tire
10
10-23-2015 05:49 AM
Sgtfluffy16
09-30-2015 01:42 PM
carid
08-07-2015 11:32 AM
Quick Reply: Voiding the warranty
