Warm A/C
Warm A/C
Hi I have an XB with 2000 miles and i have noticed that my A/C system has been slowly heating up. My heater is great but the A/C feels like its just bringing in the outside air any help would be appreciated
Take it back to the dealer and have it checked out. Sounds like it lost some refrigerant. I know that in warm weather the A/C is marginal. Echo owners have the same problem and have found that insulating the A/C tubing in the engine compartment helps some.
ken
ken
theres a service bulletin..
called the Air-mix cable adjustment
Procedure,
1) Remove combination meter.
refer to the TIS Repair Manual "INSTRUMENT PANEL SUB ASSEMBLEYY"
2) Adjust the Air-Mix damper control cable sub-assembly
a) set the temperature control **** in the MAX COOL position
b) remove the outer cable in the cable clamp
c) with the arm in the "MAX COOL" position, the clearance between the arm and prjection on the heater unit should be 1mm(0.039 inches) or less.
d) install the inner cable end on the control lever while holding the lever arm in the MAX COOL position
e) reinstall the outer cable in the cable clamp while slighty pressing it in the direciton of the arrow.
Procedure,
Originally Posted by WagenMaster
I seriously hope this is not an issue for me here in the hot desert. That's one of the reasons why I didn't purchase a Mini Cooper S--the A/C is known to work poorly in the heat. :?
Sean
GO TO THE DEALER AND GET THE TSB DONE IT MAKES A HUGE DIFFERENCE! i just wish the tsb would have come out sooner... last summer i felt like i was driving one of my old air-cooled vws. last week it hit like 96 here in phoenix so i went and had the dealer do their magic... i can oficially say "now im cool"
Originally Posted by XBman
Ok Cool thanks for all your help. ill prob go to the dealer. But would it be under warrenty? i dont want to pay a cent!
Scion will back you up with these Limited Coverages:
Basic Coverage:
All components other than normal wear and maintenance items are covered for 36 months/36,000 miles.
Checked mine today (MD, 73F WOOOHOO!!). Seems fine to me. It was ofcourse the first time. Yeah, have the Toy Dealer perform the TSB. I'm going to have mine done for the A/C as well as all the rattle noises. Just heard mine today, with the rear seats folded down. WOOOHOO
I had the same problem and went to the dealer (World Toyota) to have it checked. I gave them the TSB# and they said it was not defective and nothing could be done because the item was not recalled. I spent 1.5 hours waiting for them just to tell me that. On top of that, I saw the technician joyriding in my ride "to make sure". He "made sure" after riding around their parking lot for 5 minutes-What the ef? I was ____ed. The technician had the nerve to ask if I pressed the AC button and if I turned the dial to blue-dumb ___! Then he tries to explain that the TSB only refers to adjusting the cables so that the dial can turn all the way to the blue. He was BSing me. So, still not as cool as could be, but bearable. While the weather is still comfortable, what do you suggest I do? Time is money and I can't stand to wait idly in a crappy service lounge or watch them mess around in my ride. Can I just DIY?? Or rather DIM?
Originally Posted by elzy0000
from what i understand all TSB are free... to toyota a tsb is basically a recall but they dont like to say recall
Sean
yeah sean i got mine done the other day... i dont think you have to worry about it because the problem was apperently fixed after a certain production date
Sean
