When to replace fluids...
I believe every dealership has their own service list when it comes to 30k service with Scions. You'll have to check on specific dealership websites to get details on what service is included at their advertised price for that type of service. At $220 for a Scion 30K service, I believe they do LOF, rotate tires, air filter change, fuel injection cleaner, clean & adjust rear brake drum, wiper blade replacement, & point inspections, basically a 15k service. The 30K for $500 is probably every service just mentioned with a trans flush and coolant flush. I know the life of the coolant in Scions are at 100,000 miles. The trans fluid, however, depends on how hard you worked up the transmission within the 30k on the ODO. Honestly, I would get the LOF, rear brake adjustment, & trans flush done only for about $250. You can do the other services yourself.
Originally Posted by thunderbox
what is the refilling procedure on the auto xb i.e engine running at op temp with gear selector in nuetral or engine off do you run it through all the gears and then check i plan on doing this soon and i dont want to screw something up someone please help
Oil
Filter
DaBlackBox
134
04-10-2022 02:04 PM
TheTripleC
01-04-2015 06:46 PM
