xB drivers seat rocking problem, Anyone else? **vid inside**
Old 10-16-2004 | 01:18 PM
tcm_xB's Avatar
Default xB drivers seat rocking problem, Anyone else? **vid inside**
The other day I noticed my drivers seat moved when taking a corner. It felt like the seat was not all the way in place and made the small movement into the railing. A day or so later the same thing happened.
Well last night I had a full car (4 of us riding out) and the same thing happened again. ____ed off I had my brother check out the seat as now I figured out just by moving my weight forward on the seat the side closest to the e-brake rocks back and forth. After looking closely we're guessing there is a problem with the seat connection at the railing.
Anyone else notice this with their xB? I moved the seat up a little just to see if it only happens when fully back on the rail. The "rocking" in my drivers seat happens at any seat position on the railing. Is there a TSB for this? Can some of you check your seats to see if you have this problem as well? the passenger seat seems to be fine as my g/f tried to move it like I did the drivers. I'm going to get another look now that it's light outside and also check the passenger seat.
Old 10-16-2004 | 02:52 PM
tcm_xB's Avatar
Here is a vid I just took using my digital camera. You can hear the seat rocking as I push on the back of the chair. I am pushing at the bag clip location. Something is definitely wrong with my drivers seat.........
**right click save as (2.31mb)**
http://www.we-todd-did-racing.com/we...ZmQzMXk1NDE%3D
**right click save as**
I am not using very much pressure at all. Just a small nudge and the seat moves back and forth.
Old 10-16-2004 | 03:19 PM
rogcjms's Avatar
NM SCIONS
Hey I kinda have the same problem but my seat doesnt move when I'm taking a turn. I notice some kind of movement when I'm just sitting in the seat and driving. Like if I move a certain wait it seems like the seat isnt fully bolted in. It's really hard to explain but it moves a little when I'm sitting. I havent noticed anything like what your saying but I'll check it out today.
Old 10-19-2004 | 04:39 PM
CBSIMONSEZ's Avatar
I noticed that i have a slight movement in my seat stopping and starting. I had the dealer check it out, and he said that some movement is considered normal.
Old 10-24-2004 | 02:41 AM
ayS's Avatar
ayS
err...i just gota oil change and the fools there messed with my seat, now it is a slighty loose too! argh...bastards hehe..... anyone take it to the dealership yet to have it checked out? and if so...what they do to tighten it?
Old 10-24-2004 | 02:57 AM
fr130's Avatar
This may help. Didnt rock but it did squeek each time I moved around while sitting.
https://www.scionlife.com/forums/viewtopic.php?t=19139
Old 10-25-2004 | 11:03 AM
tcm_xB's Avatar
I'm going to take my Box in to get this looked at as well as the TSB's......
Thanks!
Old 10-30-2004 | 01:11 PM
tcm_xB's Avatar
My Box is at the stealership right now getting the gauge cluster rattle, steering wheel alignement, and the rocking seat looked at.
When showing the tech my seat he stated, "The drivers seat is designed to have a little movement".
Can you guys check your seats like in the vid above?
Thanks!
Old 10-30-2004 | 01:24 PM
fr130's Avatar
Yeah I just check mine (both front seats). It does that. I think the reason is everytime you get sit down there's several adjustments the driver has to make to sit comfortably. If there's not that movement, then there's too much tension and the seat over time will break. :? I thought the seat tracks (move closer to the wheel or farther adjustments) were giving you a problem. If it was the seat tracks then that would have been a NHTSA issue.
TheSilencerTC
Scion tC 2G ICE & Interior
02-24-2015 04:56 PM
AbsoluteRedtC
12-31-2014 06:18 PM
fluxingnation
12-26-2014 04:28 PM
minter66
12-15-2014 01:45 PM
subcode
12-06-2003 11:28 PM
Quick Reply: xB drivers seat rocking problem, Anyone else? **vid inside**
