SLR Cameras
Old 03-12-2008, 06:56 PM
CarbonXe's Avatar
Default SLR Cameras
Yes I know theres a thread about the D40, which is the camera I'm looking at. I even posted there. Anyway, I'm looking into getting a good SLR camera, which is friendly for noobs. I've only used compact digital cameras in the past and was looking into getting a good camera. Anyone have any suggestions other than the Nikon D40? I'm looking to spend up to $600.
CarbonXe is offline
Old 03-12-2008, 07:02 PM
bluaeon's Avatar
D200? D300? D40x?
bluaeon is offline
Old 03-12-2008, 07:05 PM
CarbonXe's Avatar
I was thinking more along the lines of, other brands . I refuse to buy Sony, and I've heard come good things about the Canon Rebels. Anything else out there worth looking at?
CarbonXe is offline
Old 03-12-2008, 08:12 PM
teamben158's Avatar
Nikon. Canon sucks. Other brands worth looking at are way more than $600.
teamben158 is offline
Old 03-12-2008, 08:20 PM
CarbonXe's Avatar
http://www.newegg.com/Product/Produc...82E16830113086
CarbonXe is offline
Old 03-12-2008, 09:01 PM
teamben158's Avatar
http://www.adorama.com/INKD40X.html
http://www.adorama.com/NK5018AFDU.ht...01.8&item_no=5
The kit lens on the one you posted isn't all that great. I have it and it takes only so so pictures. Not very good at indoor shots.
What type of photography do you think you'd do the most?
The 1.8 I linked is a cheap, but very sharp lens. IMO, a necessity for any Nikon user and it's only $100.
Old 03-12-2008, 09:35 PM
CarbonXe's Avatar
Thanks, I know I've heard that it's all about the lens. I don't mind if it doesn't take the greatest pictures, I just want to learn the basics of it first, then I'll end up getting a good lens. But do you think the D40x is a better buy than the D40? D40x with lens kit is 540, and the D40 (body only) is 400 on newegg.com.
CarbonXe is offline
Old 03-12-2008, 10:08 PM
dugzilla's Avatar
I found the d40x (body only ) for 323 the other day and I almost upgraded, but to be honest with you I think the 6 megapixal pics the d40 takes is more than enough.
I love my D40 and would recommend it to anyone.
dugzilla is offline
Old 03-12-2008, 10:17 PM
Ronin Scion
Ace83's Avatar
Dont get lens kit. Get the d40x body only and get a better lens to start you off, if money is an issue the stock lens should do the job for you its just not great though. Your other option will be canon xti, great body too. Or if you want nikon and can get the d200, just go for it.
Ace83 is offline
Old 03-12-2008, 10:22 PM
SquallLHeart's Avatar
nikon and canon have both great high-end consumer dslrs, and wouldn't suggest any other brand than those two.
between nikon and canon, it's all preference and i wouldn't consider one better than the other.
SquallLHeart is offline
Old 03-12-2008, 10:28 PM
CarbonXe's Avatar
Thanks for the input guys, I guess it's going to be between the D40 and the D40x. Just saw that the comparable Canon's don't use SD cards for memory, and I just bought a 4GB SD card for my cell phone, so I can just use that in the Nikon. Thanks for the input guys.
CarbonXe is offline
Old 03-12-2008, 10:30 PM
Ronin Scion
Ace83's Avatar
If you get the canon rebels I suggest not to get their EFS lenses (dont worry theres only very few of them) coz you cant use them if you decide to get a better body like 5d. The only EFS lens i prolly will consider is the 10-22mm. In choosing the body, try and feel the camera and get which one you are comfortable holding and using the controls. The only thing I dont like about the d40x is that it doesnt have a built in autofocus motor, you have to get a lens with autofocus motor.. sure its no biggy but its an important feature for me
Ace83 is offline
Old 03-12-2008, 10:33 PM
CarbonXe's Avatar
D40x - Focus Type - TTL phase detection by Nikon Multi-CAM530 autofocus module with AF-assist (range approximately 0.5-3.0m/1ft. 8in.-9ft. 10in.); Detection range: -1 to +19 EV (ISO 100 at 20 degrees C/68 degrees F)
CarbonXe is offline
Old 03-12-2008, 10:34 PM
Ronin Scion
Ace83's Avatar
I see that you are buying online, I would suggest going into stores and trying them.. see how you like those. Yeah most use compact flash memory and might also be the case when you upgrade. SD cards are more universal though so + on that one
Ace83 is offline
Old 03-12-2008, 10:36 PM
CarbonXe's Avatar
Yeah I plan on getting a feel for them, I'll probably go to a Bestbuy or Circuit City to check out the interface. User-friendly isn't much of an issue, I'm good at learning out to use electronics quickly.
CarbonXe is offline
Old 03-12-2008, 10:37 PM
CarbonXe's Avatar
Yeah, everything I have uses an SD card...cell phone, current camera, Wii...That's why I went out and got a 4GB card .
CarbonXe is offline
Old 03-12-2008, 10:38 PM
Ronin Scion
Ace83's Avatar
it has autofocus but no motor built in the body, you have to use a lens that has the autofocus motor drive
Ace83 is offline
Old 03-12-2008, 10:39 PM
CarbonXe's Avatar
The specs for the D40x for body only say it has auto-focus...Maybe they just copied the specs from the kit.
CarbonXe is offline
well, as ace mentioned, find a store where you can look at the cameras in person. check out and ask around to see if there are any professional camera stores around.
shop around for prices, and if you decide to purchase online, lemme suggest B&H photo
Old 03-12-2008, 10:40 PM
CarbonXe's Avatar
I guess newegg.com was wrong.
Auto Focus only for AF-S or AF-I lenses
As with the D40 the D40X doesn't have an built-in focus drive motor which means it can auto focus only with lenses which have their own drive motor (AF-S and AF-I lenses).
CarbonXe is offline
Quick Reply: SLR Cameras
