Who has hydrolocked their Scion?
Ok, since most here think a Scion, any model, can be hydrolocked when running a CAI, or SRI, let's hear who has.
If you have hydrolocked your engine on your Scion, please list model, which intake, and the conditions that has caused it.
I have not, and ran w/o my inner fenders, during the rainy season, just to see if it would happen, and it didn't.
I have an xB w/ an F5 Fujita SRI. When I did my own independent test, it was equipped w/ an INJEN SRI.
I also forgot to mention that my filter is in the air/water flow from the middle grille on my xB. So water does have a direct path to my intake filter.
Here are the pics:
The filter can clearly be seen in this pic:
Here are the pics:
i never have and never will!!!
i might of at work with the work trucks but i was power washing/steam cleaning some of the engine bays with the motor running, got enough of the of the water mist into the carb it stalled
Team No Limitz
Re: Who has hydrolocked their Scion?
People are still buggin out about that????
Originally Posted by SmokingTires
My car stalled once when it was raining hard in S.F. and wouldn't idle, I have a Injen SRI. Once the filter dried it ran fine.
Click here
nope. i did have it sputter in an ice storm (filter iced over on the way back to college).
ive also had to dissemble the whole intake system due to the last snow storm as it got the filer wet and inside the piping wet. i chose not to try to start and let it dry.
works good now and i have the box back
Team No Limitz
Click here
Originally Posted by killerxromances
hydrolocking is so rare, its more of a myth.
Its near impossible to hydrolock while driving, because if conditions are well enough to actually drive, there is no way water will be deep enough to cause harm.
Cya
Cya
Cya
Cya
Cya
Team No Limitz
maybe we should have them make a sticky on top of the N/A sections about how much water you would really hafta take in to lock the motor up, and they shouldn't worry about a lil puddle or some rain with an intake unless you are running open wheel wells, and drive through a 4 foot puddle and decide to stop and eat lunch in the puddle while the car is running lol lol lol. Holy run on sentance.
I hear stopping in 4ft puddles, and eating breakfast with open wheel wells also has the same effect. Tests on dinner related meals have not been tested as of yet. I'll keep everyone posted.
Cya
gosh you cannot "hydrolock" an engine unless it inhales from submersion, like running into a deeply flooded road.
If the water were only fed in like from heavy splashes, the effect would be to sputter and kill the ignition process.
The effect of plentiful of water splashing in the engine intake but no so much as to affect the seeming-power of the engine is probably not harmful, for water vaporizes and passes out the exhaut. But to shut down the engine very just after it has sucked a lot of water, say from splashing into an OPEN intake is not good for the internals: rust would stain the bores and rings if left shut off for days on end.
If a filter is on the intake, all that the engine is going to get in a rainstorm is a mist and controlled aspiration of water.
In some ways, the engine might even run better and sweeter for the extra water.
For as long as cars have been run on the roads, motorists have noted how the engines run sweeter when the air is saturated with moisture. There's a reason for this, but not germane here.
I have stock intake and don't intend to change it because- I don't want to hydrolock the engine if ever i -must- plow through a flooded dip in the roads here, say, after a tropical storm or hurricane some other rain event.
Back in the days, pouring water through a running engine was a shadetree mechanic's way of decarbonizing the pistons and heads. I've personally poured a gallon of water through a 1600cc Datsun engine in less than a minute with no ill effects.
George
I initiated this thread because there are some who believe this will actually happen. There are plenty of us who know otherwise, and I just wanted to show what conditions are actually needed for it to occur. And they are not conditions that the overwhelming majority will see.
