tC: FS: TRD Supercharger kit
I am selling my TRD supercharger kit off of my car. It has about 20k miles on it.
It is currently on the car, but i will be taking it off next week. The reason for the ad is because i need to trade oil pans.
What is going to be included:
Supercharger, shaft, brackets, tapped oil pan, oil tee, 05-06 tc ECU reprogrammed by the Scion dealer when installed, oil lines, intake, charge pipe, bosche bpv, vacuum lines and tees, etc.
I am selling for $1000 OBO I am in Bakersfield, CA
Also see my other thread for the gauges
Supercharger, shaft, brackets, tapped oil pan, oil tee, 05-06 tc ECU reprogrammed by the Scion dealer when installed, oil lines, intake, charge pipe, bosche bpv, etc.
It is for the tC. NOT the xA.
Thanks for clearing that up..
Nothing has been altered on the kit. Except the NST 9.5 pulley.
Still for sale.. anyone? $800?
question for ya. i see that you said you need to trade the oil pans. i am very interested in getting a supercharger however i would not be installing it for awhile until i can get a engine management and the supercharger rebuilt just to be safe. do you know if the tapped oil pan would be able to be adjusted to work on mine until i am able to get the kit installed? also mine is a 2008 so i would not need the 05-06 ecu so how much would you take off to keep that and sell that separately?
if you are asking if you can install the tapped oil pan now, the answer is yes, you'd just have to plug the hole. let me know if your still interested.
definitely am interested but funds are tight to be able to afford the whole price of it right now. just got done doing new tires, dezod header, new custom exhaust, some interior fiberglass and paint work, exterior paint work etc. i will see what i can do and keep you informed if it hasnt sold by then. like i said i really am interested, but just dont want to dip the account into the safety bumper i have for emergencies lol
Still in the process of removing it.
Ill be posting pictures of everything, some things had to be modified on the kit, so please wait for pics, as i dont want to scam anyone here...
First things i noticed while removing some of it...
Supercharger is leaking oil out of where the shaft meets up to the main piece... im sure its just the seal that is leaking.
The drain to the oil pan was ripped, so i cut the hose, added a small section of hose with a coupler, ive had it like this for a while now, and it has NO leaks.
The 9.5 pulley seems to be stuck on the shaft. It won't budge. ALSO, the aftermarket pulley looks beat up, but it is still fully functional.
You will see with the pics. Ill try to post them tonight.
Thanks everyone.
Thanks everyone.
ok changed.. i am in california.
anyway, here are the pics after finally getting it removed and quickly cleaned it up.
first of all, the main bracket holding the s/c is broken and the piece that broke off has a small crack. see the pic below. this may or may not be able to be fixed with some jb weld... this kit is sold as is.
second - the pulley has a little damage, but does not affect the function.. the belt stays on just fine.. no problems caused by this.
third - the drain line broke, and was fixed by adding a piece of hose and coupler.. no problems caused by this either.. just want buyer to know.
and the other piece.. one of the idler pulleys was replaced with a bigger pulley to make up for the a/c delete, but i do have the original idler pulleys (both of them)
so im dropping the price to $600 shipped.. OBO let me know if anyone is still interested. Yes the kit has a small amount of damage, but think of it this way, you may never be able to buy this kit for this low anywhere else.
I promise you this thing has no issues under full abuse. This kit has been on the car for about 30k miles with no issues, just a little oil leak out of the supercharger.
ColonelSanders85
12-09-2020 09:44 AM
rain7905643
12
06-13-2018 05:34 AM
ColonelSanders85
03-03-2015 03:31 AM
TheTripleC
01-04-2015 06:46 PM
2008, 2012, dealership, frs, kit, ny, review, roc, sale, scion, shaft, supercharger, supercharget, tc, trd, turbo, turbocharger
