turbos, exhaust, intakes
SOLD!
Old 12-31-2009 | 01:27 AM
ippskidder's Avatar
1UP Crew
Default SOLD!
FS: Scion TC Extended Clutch Slave Cylinder Pushrod
Many people have found that aftermarket clutches, especially those with heavy pressure plates, make complete disengagement of the clutch difficult.
This makes gear changes difficult and may make the transmission grind when shifting from neutral. This clutch slave cylinder push rod is ¼” longer than stock and is made from CNC turned 303 stainless steel.
This slightly longer shaft puts the slave cylinder piston further back in its bore, thus allowing a longer stroke and more disengagement. Installation is simple, and does not require bleeding the clutch.
Brand New.
Originally got it $35 shipped.
Shoot me an offer..
Old 12-31-2009 | 03:23 AM
chicotunner07's Avatar
so your saying i could swap out clutches and not have to bleed anything?
Old 12-31-2009 | 03:28 AM
ippskidder's Avatar
1UP Crew
This is just the push rod.
It is a rod that resides in the clutch slave cylinder.
It'll help to fully disengage the clutch disc when you press on the clutch pedal.
No bleeding is required when you swap the rod out.
Old 12-31-2009 | 01:52 PM
ippskidder's Avatar
1UP Crew
BUMP!
Old 01-02-2010 | 02:52 PM
ippskidder's Avatar
1UP Crew
BUMP!
Old 01-05-2010 | 11:40 PM
ippskidder's Avatar
1UP Crew
BUMP!
Old 01-07-2010 | 02:17 PM
ippskidder's Avatar
1UP Crew
BUMP!
Old 01-07-2010 | 06:59 PM
skinnayyy's Avatar
Team Scionara
pmd
Old 01-07-2010 | 08:15 PM
ippskidder's Avatar
1UP Crew
SOLD!
Old 01-08-2010 | 01:21 AM
highvoltage1's Avatar
I dont have the funds now could you PM me where you got this. Thanks.
rain7905643
06-13-2018 06:29 AM
Luna7ic
09-28-2015 04:30 PM
MisterSkiz
09-27-2015 11:25 PM
jdmautoimports
Regional - Canada
09-24-2015 05:00 AM
