turbos, exhaust, intakes
Any: <SOLD> FS: CXR 3" 304SS exhaust, new 2.75" oval K&N filter, 370cc Denso Fuel Inj's
Old 07-09-2010 | 05:30 PM
Mdiesel64's Avatar
Originally Posted by ScionFred
I didn't get your PM.
just resent, not sure what happened
Old 07-10-2010 | 06:09 AM
ScionFred's Avatar
PM received and replied to.
Old 09-07-2010 | 06:24 PM
ScionFred's Avatar
bump
Old 09-15-2010 | 10:08 AM
ScionFred's Avatar
Bump.
ScionFred's Avatar
bump
Old 09-18-2010 | 01:00 AM
ScionFred's Avatar
Bump
Old 09-18-2010 | 09:41 AM
DJ_FroZone's Avatar
what does motor mount do?? and i wish u had that s pipe! thats the last thing i need.
Old 09-18-2010 | 09:58 AM
ScionFred's Avatar
The front motor mount helps to limit engine torque movement and wheel hop during hard acceleration. It also improves shift feel and precision with a MT by reducing movement within the shift linkage. The trade-off is increased vibration felt in the cabin which is at it's worst with a AT being held back with the brakes. I can't recommend the 95A bushings for anything short of racing but the softer 70A bushings would make a noticeable improvement for any MT car without adding much vibration. The MM doesn't add as much benefit for an AT car but adds a lot more cabin vibration which is why I'm selling it.
If all you need is the S-pipe, you can get it from ebay for $100. Note that it only bolts up to the CXR scuba-delete mid-pipe though. For $200 you could have a full 3" exhaust in 304 SS with a polished muffler and 4" tip.
Old 09-22-2010 | 03:06 PM
DJ_FroZone's Avatar
hmm yea but i got that strup and the ebay cat...so i might just have to custom fab one
Old 09-23-2010 | 04:36 AM
ScionFred's Avatar
Are you AT or MT? If MT you would probably like the GGP MM. It improves shifting, reduces wheel hop and doesn't add much vibration with the softer inserts. If you're AT, it adds quite a bit of vibration when stopped in gear with the AC on. Too much for me to live with.
For the s-pipe, find a good custom exhaust shop and have one made. I could have had a complete mandrel bent custom exhaust made in 2.5" or 3" for $500-600 but by doing it piece meal it cost me about $1000. Live and learn.
Old 03-01-2011 | 08:29 AM
ScionFred's Avatar
Buy my stuff
BUMP
Old 07-18-2011 | 07:08 PM
ScionFred's Avatar
bump
Old 07-25-2011 | 11:34 PM
r2d2michael's Avatar
so you still have the cxracing setup?
Old 07-26-2011 | 01:12 AM
ScionFred's Avatar
Sure do.
Old 07-26-2011 | 02:10 AM
so with this setup it is completly diff than stock from the header back right. so i cant bolt the mide pipe and back up to my weapon r s-pipe? it is pretty much header all the way back.
Old 07-26-2011 | 03:21 PM
dguzzardo22's Avatar
If u still have the meth kit pm me
Old 07-26-2011 | 06:23 PM
ScionFred's Avatar
I'm selling the CXR scuba-delete, mid-pipe and axle-back pipes. The CXR s-pipe is still on my car. I doubt that the scuba-delete will bolt up to the WR s-pipe without a little cutting and welding. You can buy a new CXR s-pipe from ebay for $100 and the whole exhaust becomes a bolt-on affair or you could have a shop mate the CXR scuba-delete to your s-pipe.
Total cost would be $200 for a complete 3" CXR exhaust or less if you use your WR s-pipe. Any decent exhaust shop can weld a new flange on to mate your WR s-pipe to the CXR pipe.
Old 07-26-2011 | 06:44 PM
this is very very tempting. i just dont want it to be super loud.i want a deep almost wrx sound. i have herd your sound clips if it and video and audio never sound the same in real life....IYO did it have a drone to it on the freeway at 60-70mpg or was it deep?
Old 07-27-2011 | 06:27 AM
ScionFred's Avatar
The CXR 3" is by far the deepest sounding exhaust I'ver ever heard on a 2AZ-FE. However, it is also super loud and there is plenty of drone. The solution is to add a long 6" round resonator where the "scuba" was. I did this (7" but a little too big) and it sounded great but still a little too loud for this 48 yo. That's why I went 2.5" and TRD axle-back. I'd describe the current sound as being not as deep as the CXR but only as loud as a factory performance car.
Old 10-05-2011 | 12:52 AM
ScionFred's Avatar
bump
