Any: Arc Audio 400.4 amplifier
Up for sale is my Arc Audio 400.4 KAR series amplifier. I had it run my MB Quart components for the past few years. It is an incredible amplifier, and made right here in Modesto! It is in excellent condition! The newer model runs the same power, but in a new black shell.
I will take $140 SHIPPED within the 48 states. I live in Nor*Cal if you want pickup. Other than that, if you have any questions please ask me. Thanks for checking this out!
Test Results
Measured output power (At 14.4 Vdc less than 1% THD+Noise): 70.2 x 4 into 4 ohms, 124.2 x 4 into 2 ohms, 248.5 x 2 into 4 ohms bridged.
Measured Current Draw (At Max Power): 27.8 amps into 4 ohms stereo, 47.7 amps into 2-ohms stereo and 4 ohms bridged
Measure Amplifier Efficiency (At Max Power): 70% amps into 4 ohms stereo, 72% amps into 2 ohms stereo and 4 ohms bridged
Measure 1/3 Amplifier Efficiency: 32%
Signal-to-noise dBA (Reference 1 watt): 92 dBA
Rated OutOutput power: 50 watts x 4 @ 4 ohms, 90 watts x 4 @ 2 ohms, and 180 watts x 2 4 ohms bridged
Transient distortion: less than 0.1% @ 4 ohms
Frequency response: 20 Hz-20 KHz
S/N ratio(A wtg): greater than 95 dB
Bass boost: + 18 dB @45 Hz
Input sensitivity: 250 mV - 2.5 V
Crossover: 55 Hz-5.5 KHz variable 12 dB
Fuse: 40A x1
Dimensions: 13 inches x 8.5 inches x 2.5 inches
Test Results
Fuse: 40A x1
pjl52
08-13-2015 02:38 PM
marsman328
Regional - Pacific Mid
07-28-2015 09:43 PM
