FS: xB1: Audio Formz Enlosure, Amp Rack, Other Stuff
Selling most of a system for a Gen 1.
Audioformz - Amp Rack/Sub Enclosure - Painted: TCM - SOLD
VooDoo - 2.4 Farad Cap with Digital Display (Blue LED trim ring)
Memphis Audio Power Reference PR100.2 Amp
VooDoo - Warrior Series wiring
Miscellaneous: "T" joint, 2 grounding feet
All Installed (does not include sub and you must transfer the hatch latches to the components - these are shown, but not included):
All Components:
Memphis Amp - Light Scratch on the silver side of the "M", works perfect, has never popped a fuse or "over heat" shut down on me, far exceeds 100 x 2 rating. That amp blew apart a Memphis 10 rated at 400W, bridged and at 50% gain! And, "T" for splitting off to the cap.
Amp Rack inner tray, you can see the holes drilled where the wires were run, and two screws in the bottom where I once had a meter mounted, but removed.
You must hack up the foam insert to install the amp rack.
Sub Enclosure fits 10" woofer, poly filled
Here is the speaker terminals for the enclosure, and on the left you can see where I mounted foam tape to rid a vibration.
In this area of the sub enclosure (left front lip) there is what looks like a spider web under the paint, in certain light. It arrived to me this way. The camera would not pick it up, in certain lights it sticks out like a sore thumb, in other light.. you cannot find it. It is definitely under the paint and very light, you cannot feel it by hand.
In the back of the sub enclosure, I thought I found a hair line crack, but I sanded it down and it disappeared, I back filled it with fiber glass resin and applied a fiberglass patch 3/4" extended above and below the repair area, and 2"'s longer than the repair at each end. It is a solid patch, that is hidden completely once installed.
The cap, the blue LED glowing trim ring at the top stays on at all times, the digital display shuts down with the vehicle.
All the wiring from battery back is here.. minus the RCA cables to the head unit. Includes grounding feet, and fuse block.
The Audioformz amp rack and sub enclosure go for $799.98 New, in your cart painted, not including shipping and the 2+ week wait.
Audioformz amp rack $175.00
Audioformz sub enclosure $SOLD
VooDoo Wiring, 2 ground feet, "T" connector and Voodoo Cap $30.00
Memphis Audio Power Reference 100.2 amp $50.00
All Components:
Update - Individual Component Pricing
marsman328
Regional - Pacific Mid
07-28-2015 10:43 PM
