FS TC:UPDATED!!!!!Dezod S1 turbo kit w/ upgraded turbo,Emanage and extras.
UPDATED!!!!KIT WILL BE OFF THE CAR BY FRIDAY!!!!
WILL FIT ON ANY TC 2007 AND UP
Im selling my dezod s1 kit, been on the car for about 10k.
no problems with the kit except manifold did crack before but it has been professionally TIG welded since.
the manifold has also been re-enforced so it will not happen again.
other than that, not a single issue.
im going to be going back to stock and im broke, need money asap.
im not into the speed thing anymore.
It comes with the upgraded s2 kit precision turbo w/ the ball bearing upgrade
turbo by itself is over $1000
Turbo is in immaculate condition as well as the rest of the kit.
Turbocharger specs....
Compressor Wheel Diameter 54mm
Compressor Wheel Inducer - 2.123
Compressor Wheel Exducer 3.000
Wheel Trim 50 Trim
Compressor Cover Inlet 3
Outlet Size 2
Bearing System PTE Race 360 Center Section
Turbine Housing A/R Ratio - .48 or .63 5 Bolt Turbine Housing
Turbine Wheel Style - T31 (Stage III)
Turbine Wheel Inducer 2.559"
Turbine Wheel Exducer 2.229"
Turbine Wheel Trim - 76
the kit includes.....
Dezod Turbo Manifold
TiAL 38mm Wastegate
Dezod Intake w/ AEM Dry-Flow Filtered Intake
Dezod catless downpipe.
Dezod s pipe.
Black limited edition HKS SSQV Blow Off Valve
550cc fuel injectors
Dezod Stainless Steel Braided Oil Feed Lines
Dezod stainless steel oil return pan system
Dezod Front Mount Intercooler
Dezod Vac Manifold
All t bolts and couplers
spring bolts for s-pipe
Greddy emanage ultimate w/ pnp harness
professionally tuned by ptuning.
im pretty sure if it is used on another auto the tune can safely transfer, i could be mistaken.
This kit alone is $4,525 from dezod w/o shipping
and that includes aem fic which is around $350 depending where you buy it.
the kit im selling is all of the above but with emanage ultimate, which is around $600.
so the kit new is worth $5,125
and the emanage is professionally tuned by ptuning for an auto already, which was $650
grand total of $5,775 FOR THE KIT WITHOUT THE EXTRAS LISTED BELOW.
ALSOOOOOOOOOOOOOO
I will also be selling three 10 inch mishimoto super slim cooling fans and the mishimoto dual core performance radiator.
radiator and fans work great, no leaks or rust.
dont need it if im not boosted.
each fan is $75 and the radiator is $275 shipped new.
thats a total of $500
I have a turbosx manual boost controller, literally brand new, JUST put it in the car.
that was $125 and i have the hallman manual boost controller which was also $135
ill include either one of your choice with the kit for free.
I also have the tanabe exhaust concept g, $400 new
all these items retail for $1,255 w/o shipping
this is absoloutly everything you need.
turbo kit , exhaust,boost controller,pre tuned emanage and cooling system.
complete bolt on and plug in /e-manage already tuned to 225whp 220tq
I WILL ALSO THROW IN MY B&M TRANS COOLER FOR FREE
AND THE BOOST CONTROLLER FOR FREE IF YOU BUY EVERYTHING.
all in all this kit with everything is worth
$7,030
im asking
$4,000 FIRM for EVERYTHING.....thats $3,000 less than cost.
$3,000 FIRM FOR EVERYTHING EXCEPT WHATS HIGHLIGHTED IN GREEN
local pick up only because i want you to see the kit in person, make sure everything is there, so you know what our getting.
I will also trade this kit for an audio system with a dvd/nav unit and $2,500
REMEMBER, THIS IS EVERYTHING YOU NEED. EVERYTHING!!!!!!!!!!!
random video w/ sound clips of exhaust
http://www.youtube.com/watch?v=lnQVBhHhQgE
Wheel Trim 50 Trim
Outlet Size 2
TiAL 38mm Wastegate
Dezod s pipe.
Dezod Vac Manifold
ALSOOOOOOOOOOOOOO
$7,030
im asking
SloTC1
08-16-2018 02:45 PM
05rs1
12-09-2016 02:18 PM
CrowJenkins
10-09-2015 10:47 PM
