2009 Scion Tc
2009 Scion Tc
2009 Sizzling Crimson Scion Tc 5 Speed with 15494 miles. I am going to try to sell her with everything I have for her for $18000. If she doesnt end up selling I am going to part her out return her to stock with the exceptions of shifter, springs, and mounts and sell her for $14000. Maintenance wise I've changed the oil every 2000 miles with Mobil 1 Synth 0w20 then 10w30 when turbo was installed. Tranny Oil changed at 8000 miles with Redline MT90.
Parts Installed all about 900 miles or so
Dezod APR X1 Inline ECU
Deatschwerks 700cc Injectors
Tial 38mm Wastegate with Tial 5.7 psi spring
Hallman Pro RX Boost Controller
Precision 60-1 T3 .63 AR Stage III 4 Bolt Turbo
DEI Titanium Heat Wrapped 321SS OBX R Ported and Polished Top Mount Manifold with EGT bung
DEI Heat Wrapped 321SS 2.5" 4 Bolt Recirculated Dump Down Pipe with O2 Bung
DEI Heat Wrapped 2.5" Mandrel Bent S Pipe with 2 O2 Bungs
2.5" Mandrel Bent S Pipe Back Exhaust with SS Magnaflow Straight Through Muffler
HKS SSQV V2 BOV
Gloss Black 2.5" Aluminum Blow Through Intercooler Piping
Gloss Black 3" Aluminum Intake with Fujita Dry Flow Filter
Ingalls Stiffy Torque Damper
Energy Suspension Motor Mounts
Weapon R Catch Can
10 AN Oil Return Line
Oil Pan with welded 10 AN Bung
Dezod Oil Feed Kit
Dezod Gloss Black Intercooler
Tien S. Tech Lowering Springs With Camber Bolts and on Factory Spec Alignment
Dr. Isotope Short Shifter with Delrine Shift Cable, and Cage Bushings
DME SS Diversion Panel
ATI Gauge Pod
Glowshift 60mm Elite 10 Series Wideband, EGT, and Boost Gauge
Grilles Painted Gloss Black with Sizzling Crimson Badge
Rear Badges Painted Gloss Black
Window Tint 35% Front 15% Sides and Rear
Parts Not Currently Installed
Fidanza Flywheel
Dezod 850cc Injectors
Dezod Stainless Steel Braided Clutch Line
Stock Injectors
Stock Exhaust System
Stock Intake System
Stock Lines
Stock Oil Pan
The Kit is completely reversible with absolutely no footprint. No stock part was used to make the kit.
HKS SSQV V2 BOV
Weapon R Catch Can
Dezod Oil Feed Kit
ATI Gauge Pod
Fidanza Flywheel
Stock Injectors
Stock Intake System
Stock Lines
Stock Oil Pan
foxSCION
13
12-03-2003 05:40 AM
