FS: Pair of Wheel Spacer Adapter 20mm 5X100 To 5X114.3 / 12X1.5 100 SHIPPED
Old 12-17-2010 | 05:56 PM
Dilirious's Avatar
Default FS: Pair of Wheel Spacer Adapter 20mm 5X100 To 5X114.3 / 12X1.5 100 SHIPPED
Selling:
100 Shipped or OBO
Wheel SpacerAdapter
20mm
5x100 to 5x114.3
12x1.5 Stud Thread
Description:
Only used once to test how far it spaced out the wheel other than that never driven on. Basically for putting 5x114.3 wheels on our 5x100 studs. Also another application is for dual drilled wheels which are 5x100 and 5x114.3 don't have to worry about the studs on the hub interfering with the wheel because the hub studs will just go through the 5x100 and the studs on the adapter go through the 5x114.3.
Old 12-17-2010 | 06:20 PM
xxTC1488xx's Avatar
PM'ed
Old 12-18-2010 | 05:16 PM
Dilirious's Avatar
bump
Old 12-20-2010 | 04:55 AM
Dilirious's Avatar
bump
Old 12-21-2010 | 08:54 AM
Dilirious's Avatar
bump
Old 12-21-2010 | 12:53 PM
davedavetC's Avatar
only 2?
Old 12-23-2010 | 07:33 AM
Dilirious's Avatar
ya just two reason why i only had two was because i didn't need to push out the fronts as much as the rears. cuz i still had enough thread in the front to be safe.
Old 12-23-2010 | 11:43 AM
davedavetC's Avatar
what wheels were you runnin?
Old 12-23-2010 | 05:19 PM
Dilirious's Avatar
i was running rota dpt 18x9.5 +35 that was dual drilled for 114.3 and 100. only thing was if i used a normal spacer adapter the remaining thread would hit the back of the wheel so i bought these which the stock thread would go through the 100 and the new bolts would go through the 114.3. but in the end i only test fitted them and never ran with them on.
Old 12-23-2010 | 06:26 PM
davedavetC's Avatar
That's pretty smart
Old 12-24-2010 | 03:34 AM
jeremydoc's Avatar
if u still have these by mid january, ill pick em up
Old 12-24-2010 | 07:35 PM
Dilirious's Avatar
gotcha ^
Old 01-10-2011 | 07:27 PM
Dilirious's Avatar
bump
doc i still have them if your still interested.
Old 01-10-2011 | 07:40 PM
SlowxD's Avatar
how much shipped to 33178
Old 01-10-2011 | 10:34 PM
jeremydoc's Avatar
Originally Posted by Dilirious
bump
i responded to ur pm my friend
Old 01-11-2011 | 05:59 PM
Dilirious's Avatar
pmed
Old 01-18-2011 | 06:42 PM
Dilirious's Avatar
bump
Old 01-20-2011 | 12:02 AM
Dilirious's Avatar
100 SHIPPED
Old 01-21-2011 | 04:43 AM
Dilirious's Avatar
bump
Old 01-21-2011 | 05:02 AM
jeremydoc's Avatar
bump for you man. sorry i couldnt pick these up from you
Quick Reply: FS: Pair of Wheel Spacer Adapter 20mm 5X100 To 5X114.3 / 12X1.5 100 SHIPPED
