fender rollin
fender rollin
yo anyone got hook ups on fender rollin? i just need my rears to be done..
i had someone pm me a guy before but i accidently deleted it because my mailbox was full and just deleted everything..
if you do know anyone, lemme know if they charging anything
There is always the wooden baseball bat method. Wedge a wooden baseball bat between your fender and tire (this works well because a bat tapers) and then roll it on the tire around the radius of the fender well lip-small bits at a time. The wood on the bat should slide easy enough but you can always add some sort of lube to help it along (lube the fender and try to keep the tire dry as the tires sticky properties help you move the bat as you roll it).
I did this on my VW and it worked really well and if you take your time and be gentle as you do it the paint stays looking good..
Originally Posted by BlackSandPtC
Hoped you liked how your fenders turned out John!
ill let you know >:], also nicemeeting your uncle pras too. hes so chill
umnitza
09-01-2015 08:06 PM
