Stock Trans, Stock Engine 324whp/250tq
Music City Scions
Video
http://youtu.be/bX8Cx47ofz8
This turbocharged FR-S build consists of:
· Dynosty Scion FR-S Subaru BRZ Single Turbo Kit with Tial GT2871R Turbocharger
· Tial MVR 44mm Wastegate and Tial Blow Off Valve
· Injector Dynamics 850cc Fuel Injectors running E85
· Haltech Platinum Sport standalone engine management
· Haltech Wideband and Haltech Advanced Boost Control System
· Dyno Tune by Hal at Dynosty
· Traklite 18" Wheels
· BC Racing Suspension
It's cool to see what's possible with E85 only and no concerns about engine longevity. If the engine hasn't blown up yet they need to upgrade the fuel delivery system with at least a new pump for all that E85 and there's no way the stock clutch can handle that much tq. I doubt the stock MT can either and it's a certainty that the AT can't. I wonder how beefy the rear diff is?
Music City Scions
So is the S2k, but PTuning pushes 500whp on those when they go boost. The Direct Injection from my understanding helps a lot with detonation on the FA20's.
Music City Scions
Fredrick Aasbo's 700hp 2jz swapped 86 was running a stock diff. After beating on it all day it finally decided to go kaput. But that's a 700hp motor swap. Don't see 250tq destroying the rear diff on this, nor the manual trans going out at this whp.
have you guys seen the HKS headgasket that drops the CR from 12.6?
New product announcement from HKS… Stopper Type Head Gasket for Scion FR-S and Subaru BRZ is underway.
Two gaskets will be offered for the FA20 engine:
NA 12.6:1 Compression Ratio, 0.5mm thickness, 89.5mm bore, opposed bead type – 300HP capable (PN 23001-AT002)
BOOST 12.4:1 Compression Ratio, 0.7mm thickness, 89.5 bore, opposed bead type – 600HP capable (PN 23001-AT003)
Opposed Bead Stopper Type Metal Gasket for the FA20 engine of 86/BRZ provides higher bore sealing durability than a stock gasket. Both types are endurable against high engine output. Stopper structure of the bore seal prevents leakage even under high cylinder pressure at high engine output. Boosted gaskets compression is kept high to maintain high efficiency. Contact surface pressure is improved via a special coating applied to the head side and cylinder side to improve sealing performance when tightening the bolts.
Source: http://www.dynosty.com/tag/scion-fr-s/
Is that 12.4 a typo? Dropping c/r by only .2 isnt going to make a damn bit of difference lol. IMHO, you at least need to get it down to the 10:1 range to safely make some decent power on pump gas. TBH though, its been talked about before with other cars, you may be able to get quite a bit of power on stock compression without too many issues if your run E85.
Music City Scions
TheTripleC
01-04-2015 07:46 PM
Godfryness
01-03-2015 12:18 AM
darkshadowofxdeath
12-03-2014 07:59 PM
