06 tc conversion to projector headlights
Old 11-24-2009 | 05:36 AM
Boardspinna's Avatar
Default 06 tc conversion to projector headlights
is it possible to fit newer OEM projector housings (like the ones on the '10) on an '06 tc...and if so, any modification necessary?
thanks everyone
Old 11-24-2009 | 05:37 AM
Jon's Avatar
Jon
Moderator
Moderator
Yes. For details, search plz.
Old 11-24-2009 | 07:47 AM
whitetc06's Avatar
yes it will fit fine. Unless your using Hid, you need a diff. harness cause 06 uses 9006 bulbs and the projector uses h11
Old 11-24-2009 | 08:07 AM
DJ08tC's Avatar
you will need a different harness anyways. You will have to splice a H11 bulb harness in if you want to run the stock halogens. I would be easier to get a 9006 hid kit with h11 bulbs.
Old 11-24-2009 | 11:45 PM
how would i get a 9006 kit w/ h11 bulbs...??
also can anyone point me in a good direction to get OEM projector housings...i dont want the ebay ones because they typically have a crappy lighting output
Old 11-24-2009 | 11:50 PM
DJ08tC's Avatar
trdsparks has them but they arent cheap. Whoever you buy the hids from tell them you what you want. They should have no problem sending it out like that.
sciontc008
Scion tC 1G Aero & Exterior
01-20-2016 06:10 PM
vi3tb0i09
09-23-2015 09:32 PM
alias55
Scion tC 1G ICE & Interior
09-22-2015 08:50 PM
DannyBoy65
09-21-2015 07:23 PM
Renuco612
09-16-2015 10:01 AM
Quick Reply: 06 tc conversion to projector headlights
