08 headlight TSX retrofit 56k beware
Old 03-29-2008, 08:21 PM
megrog2's Avatar
Default 08 headlight TSX retrofit 56k beware
So this is my first time attempting a retrofit. I have 08 headlights and TSX projectors.
Let's get started...
Driver's side 08 headlight
baking headlight at 225 deg
Finally got the headlight apart after alot of prying
Comparing the tsx with the stock projector
What had to be trimmed
what had to be trimmed 2
what had to be trimmed 3
what was used to mount the projector and level it out in the projector
tsx mounted in the headlight
mounted 2
back of headlight
I still have some trimming to do before I can seal up the light and then on to the passenger side. I will post mounted and wall shots once im done. To be continued.....
megrog2 is offline
Old 03-29-2008, 08:24 PM
Ronin Scion
Ace83's Avatar
watching, DIY FTW!
Ace83 is offline
Old 03-29-2008, 08:28 PM
Mari0's Avatar
hmmm watching
Mari0 is offline
Old 03-29-2008, 08:29 PM
Ronin Scion
Ace83's Avatar
there is one one DIY for this but its good to have few, some people have different ways.. im planning on s2k retrofit though
Ace83 is offline
Old 03-29-2008, 08:31 PM
Mari0's Avatar
A little off topic, but when are the angel eyes for 08 models coming out? I heard oznium is making them.
Mari0 is offline
Old 03-29-2008, 08:33 PM
megrog2's Avatar
s2k will involve alot of trimming, here is a 08 retro with s2k's http://high-intensity.org/forums/showthread.php?t=553
megrog2 is offline
Old 03-29-2008, 08:35 PM
Ronin Scion
Ace83's Avatar
yup and a lil expensive too.. but i'll see how it goes. I dont think its much deference though when it comes too light output
Ace83 is offline
Old 03-29-2008, 08:38 PM
megrog2's Avatar
yea there is a difference, http://lightwerkz.net/faq.htm#difference
megrog2 is offline
Old 03-29-2008, 08:40 PM
Ronin Scion
Ace83's Avatar
sure but i mean not much like you wont notice unless you compare s2k and tsx side by side
Ace83 is offline
Old 03-29-2008, 08:42 PM
megrog2's Avatar
yea im sure the average person wouldn't notice
megrog2 is offline
Old 03-29-2008, 08:45 PM
ADRdesignCo's Avatar
watchin.. :D
ADRdesignCo is offline
Old 03-29-2008, 11:28 PM
Scott8's Avatar
so you replaced a projector with a projector...
You should have done the retrofit on my 05 headlights and given me your 08's!!!
Scott8 is offline
Old 03-29-2008, 11:30 PM
Ronin Scion
Ace83's Avatar
x2, would have gotten extra cash if he exchanged plus cash with 04-07 HL
Ace83 is offline
Old 03-29-2008, 11:36 PM
CRUZtc8's Avatar
watching.
CRUZtc8 is offline
Old 03-30-2008, 04:05 PM
elite-fusion's Avatar
watching
elite-fusion is offline
Old 03-30-2008, 06:06 PM
striker_1818's Avatar
that is pretty nice but before taking the shield out, you should've marked with lines where the shield was. That way, you can align those marks with the tsx shield and that'd save you time on the aiming process since they already match the stockie ones. Anyways, looks good man. I'd trim the ears on the left side and use the lower mounting hole.
striker_1818 is offline
Old 03-30-2008, 06:29 PM
megrog2's Avatar
I have an 07 so but being that this is my first retrofit the 08 headlights are easier to bolt in another projector
megrog2 is offline
Old 03-30-2008, 06:49 PM
megrog2's Avatar
There is nothing to mark on with the projector out the headlight the, hole is pretty big.
megrog2 is offline
Old 03-30-2008, 07:26 PM
yes it is. Whiteout helps to mark it on the black brackets ;)
But you can always go the difficult way andd get amore accurate aiming. Do not rebake your headlights to put the lense back onto the headlight housing until it is well aligned otherwise it will be a pain to bake and rebake and re-rebake lol
Old 03-30-2008, 07:48 PM
megrog2's Avatar
The black brackets are are no where near the projector hole on the shrod to mark, the hole is too big to mark on. Looking straight in the projector shroud you won't see the black brackets. I don't intend on sealing the headlight back up until I aim them.
megrog2 is offline
Quick Reply: 08 headlight TSX retrofit 56k beware
