1 1/4" hitch install with pics
Old 01-15-2007 | 03:42 AM
Scimitar's Avatar
Default 1 1/4" hitch install with pics
I recently installed a hitch I got from HitchesOnline.com it's the Curt Manufacturing C11330/DH247330 1 1/4" receiver hitch.
The instructions are pretty straight forward and the install is pretty easy. The biggest hurdle for me was getting the hole enlarged in the frame rail. I ended up using a 1 1/4" hole saw and it worked fine. If you have a 3/8" drill you should be able to find drill bits easier in this size.
The steps are as follows:
1) Remove plastic push fastener from rear bumper fascia straps. (Reuse later.)
2) Enlarge 3/4" access hole on passenger side.
3) Fishwire 7/16" carriage bolts and square hole spacers into passenger side frame rail as shown.
4) Raise hitch into position and secure with hex bolts and conical washers through driver side weldnuts.
Install flange nuts onto carriage bolts on the passenger side.
5) Reinstall rear bumper fascia straps removed in step 1.
6) Torque all 7/16" fasteners to 50 lb-ft and 10 mm fasteners to 37 lb-ft.
It should take you anywhere from 20 to 45 minutes to install with a friend. I've drove with the hitch for over 1500 miles with a Saris Cycle-On Pro bike rack attached and had no issues.
straight on view of the receiver
rear angle view
side profile shot of the hitch
bolts attached to the frame
hitch orientation with tabs not secured yet
hitch attached to frame. Depending on what angle you want for the hitch you should tighten or loose the front or rear bolt. This picture was taken before I realized that the rear bolts should be tighten in order to tilt the hitch to the correct level.
another side picture
pic with rack attached
Has anyone else had succes with this hitch or others?
Old 01-15-2007 | 03:45 AM
Yanki01's Avatar
well nice DIY for the peeps who need this! I dont think this every went through my mind when buying this car but good job!
Old 01-15-2007 | 03:50 AM
Scimitar's Avatar
Yeah I run a downhill and freeride website so I move bikes around a lot. I have a sub so throwing bikes in the back doesn't work out anymore.
Old 01-15-2007 | 04:30 AM
Mightygnu's Avatar
hahaha nice job.
Old 01-15-2007 | 04:33 AM
Neothin's Avatar
i wonder how much a tC could pull...
I'd love to tow a little trailer to shows and such with supplies and presentation pieces
Old 01-15-2007 | 05:32 AM
etsnet's Avatar
I think it says it in the book. That's a good idea and looks like you could set it up to take that hitch off pretty quick. A small lockable enclosed trailer to carrier your slicks to the track would be nice.
Old 01-15-2007 | 12:10 PM
MJVsTC's Avatar
Hauling too much weight with a unibody frame is certainly a no-no.
Bikes won't hurt, though.
YooItsJay
12-02-2015 09:13 AM
Andreas24
38
09-22-2015 07:23 PM
SuBSiN
03-13-2015 05:02 AM
Frustratez
02-26-2015 05:03 PM
TheRedBox
31
12-02-2003 05:53 PM
