Aftermarket headlights baked and opened
Old 08-27-2006, 05:35 AM
Yanki01's Avatar
hmmm, not sure. But you can find alot of helpfull info here...
http://hidplanet.com/main.html
Yanki01 is offline
Old 08-27-2006, 03:19 PM
jeremy681978's Avatar
thanks for the info about the lights
jeremy681978 is offline
Old 08-28-2006, 03:21 AM
06tCpimpn's Avatar
still watching....
06tCpimpn is offline
Old 08-28-2006, 03:33 AM
Noodle's Avatar
Don't exactly know what you guys are waiting for when you post "waiting". I just order my projector yesterday, so I won't start swaping projector mid next week.
Noodle is offline
Old 08-28-2006, 03:35 AM
Yanki01's Avatar
which type of projector did you order?
Yanki01 is offline
Old 08-28-2006, 03:38 AM
sciontc313's Avatar
watching
sciontc313 is offline
Old 08-28-2006, 03:51 AM
Noodle's Avatar
This one:
Here are the approximate dimensions:
width: 2 5/8" Edge to Edge
width: 2 1/4" Lens
Lenth: 5 1/4" Depth without bulb holder
If you look at the two bottom screws, the orientation is exactly like the aftermarket's projector. Hopefully this will fit fine. If not, I'll make some adjustment
Noodle is offline
Old 08-28-2006, 03:56 AM
Yanki01's Avatar
what brand?
Yanki01 is offline
Old 08-28-2006, 04:05 AM
Noodle's Avatar
what brand?
BMW E46: Single xenon
Noodle is offline
Old 08-28-2006, 04:14 AM
Yanki01's Avatar
kool! Hopefully it works out well with it! keep us posted!
Yanki01 is offline
Old 08-28-2006, 05:25 AM
06tCpimpn's Avatar
Well come on man you got to update...Which projectors did you order? Because I had the same idea but glad to see someone that actually did it, I hope everything turns out great man! Keep us posted
Old 08-28-2006, 05:26 AM
06tCpimpn's Avatar
Well I take back which projects because it clearly says it right there, sorry. But keep us updated like everyone else says...
Old 08-28-2006, 05:57 AM
Remii's Avatar
Yah watching keep us updated plz! Much appreciated I can't wait!
Remii is offline
Old 08-28-2006, 11:39 PM
freeflowing's Avatar
sounds like he went with e46 projectors. if you need ballast to match let me know. i have a nice set of oem bmw ballast i just got 3 days ago for free and i could cut you a nice price you cant beat .
freeflowing is offline
Old 08-30-2006, 03:36 PM
Vlad's Avatar
e46's are easy to work with, but the performance lacks. E-code e46's are pretty nice.
Vlad is offline
Old 08-31-2006, 02:00 AM
Noodle's Avatar
It looks like I won't get the projector until friday, I'll post more when I get it.
In the meantime, I do have one question for any of electronic literate out there.
I will be using 12 LEDs (each has a forward voltages of 2.3 and reverse voltage of 5) I want to connect these 12 LEDs to the parking light wires (parking light wires have 12.7 volt. These 12 LEDs will be compiled to a stip of leds
From my calculation, I have 12.7V - 2.3V = 10.4V, which approximate 100 Ohm. Should I use 12 "100 Ohm" resistors or should I use 12 "8.3 Ohm" (100/12) resistors?????
Can someone help?
Noodle is offline
Old 08-31-2006, 02:47 AM
Strictly Scionized
LEDMods_net's Avatar
^^^ I wouldn't wire all 12 of them in series. Wire 4 in series, and have 3 groups of 4. Use 1 150ohm resistor for each group.
LEDMods_net is offline
Old 08-31-2006, 03:10 AM
Noodle's Avatar
My knowledge is very limited pertaining to the electricity flow. Can you explain how you get 150 Ohm for 4 LEDs? and why a series of 4 instead of 12?
thanks
Noodle is offline
Old 08-31-2006, 04:43 AM
Strictly Scionized
thanks
R = (Vs - Vl) / I
Vs = Source Voltage = 12.2V (you should actually test whether it is 12.2 or 14.4)
Vl = Lead Voltage = 2.3V x 4 (4 LED's in the array)
I = Forward Current = 20mA
R = (12.2 - (2.3 x 4)) / .020A (NOTE: You use Amps, not milliamps. 20mA = .020A)
R = (12.2 - 9.2) / .020
R = 3 / .020
R = 150
Old 08-31-2006, 05:01 AM
Noodle's Avatar
thanks
R = (Vs - Vl) / I
R = 3 / .020
R = 150
AHHHHHHHHH
I rely on your source base on your works with the LEDs. But did you concluded that Vs is 12.2 or was that a typo. I tested the wire and it said 12.7. If we use 12.7, then we would get 175 Ohm
Noodle is offline
Quick Reply: Aftermarket headlights baked and opened
