Aiming projector Headlights help
Old 09-12-2009 | 05:28 PM
hawaiicalls's Avatar
Default Aiming projector Headlights help
Hey guys,
I just bought some new Spec D dual halo projector headlights. They look soo sexy. I just installed my HID's last night too, but the only problem is, is that the cutoff completely sucks. On the passenger side of my car it is completely aiming at the tops of houses. And on the right side of my car it is only going about 10 feet out in front of me, and it isn't even going very far left. In another words, with both lights on, it won't even light up the width of my whole street. Which can barely fit two cars down.
I'm pretty mad, considering that I thought these were gonna be good.
Does anyone know how to aim these? I know how to turn them up and down, but anyone know how to do them left and right???
I seriously need help!!
thanks in advance.
Old 09-12-2009 | 06:22 PM
DJ08tC's Avatar
That is the problem with aftermarket headlights, the cutoff on all of them sucks. But yours does sound bad, you might want to see if you have the bulbs in straight.
Old 09-12-2009 | 06:37 PM
eggie's Avatar
I took mine apart and cut the cutoff. Now the problem is everyone things I have my highbeams on...
Old 09-12-2009 | 08:46 PM
SoleLaced's Avatar
Why would you ever want to cut off the cutoff shield?
Old 09-12-2009 | 08:57 PM
Yanki01's Avatar
lmao, I'm in for pics of both projectors!
Old 09-13-2009 | 04:07 AM
so what would you recommend that I would do?? Also, what would be the best headlights for HIDs?
How much does retrofit cost?
Old 09-13-2009 | 04:11 AM
DJ08tC's Avatar
Either a retrofit, not sure how much that would cost or get 08-10 headlights
Old 09-13-2009 | 04:12 AM
xxnyangel10xx's Avatar
if you are talking about the projector headlights u can get off of ebay, i have the same ones, if you look in the back of the headlight there is a grey dial with a screw in the middle you want to turn the dial to adjust the aiming of the headlights, i had the same problem until i did that.. if u need a picture of what im talking about LMK and ill post it up but that should fix your problem
Old 09-13-2009 | 04:16 AM
What is so different with the 08-10 headlights? will they fit a 2005?
No, i know how to aim the light up and down, just not left and right. the right side shines really far left, and the left side barely shines out of my car. almost completely straight. So the entire left side of the road is not lit up. Does that make sense?
Old 09-13-2009 | 04:21 AM
DJ08tC's Avatar
They are projectors and the cutoff is way better than the ebay lights. Yes they will fit, only difference is the bulbs are H11.
Old 09-13-2009 | 04:25 AM
do you have a link to where I can get them? That would be SOO helpful!
Dang, that stinks, I just bought H7 HID bulbs for my halo projectors.
Old 09-13-2009 | 04:27 AM
I actually bought my headlights off of fastscions.com....if that makes a difference at all? lol!
Old 09-13-2009 | 04:31 AM
DJ08tC's Avatar
08 headlights aren't cheap though, new they are like 250 each side. No it really doesn't make a difference that you go them there. No aftermarket headlight has a good cutoff that I have seen.
Like I mentioned before, you might want to see if you can move the bulbs around. You might not have them in there perfect
Old 09-13-2009 | 04:33 AM
Damn!
Wouldn't it be cheaper to retrofit then? and with a retrofit would it have a clean cutoff? Idk, this all just got really confusing hah.
If you all were to recommend to either buy the 08-10 headlights or retrofit, which would you choose to do?
Old 09-13-2009 | 06:01 AM
eggie's Avatar
read it somewhere, thought it should be something I needed to do...
Guess not.
Old 09-13-2009 | 06:16 AM
hahaha! ^^^
so my lights are completely in and straight. Guess i better go with the oem projectors huh? is TRDspark.com a reliable place?
Old 09-13-2009 | 06:23 AM
DJ08tC's Avatar
Yes they are very reliable. Maybe you can post some pics of how bad it is?
Old 09-13-2009 | 06:35 AM
Oh i definitely will! I will have them up by tomorrow! so right now, just warning everyone, don't buy halo headlights from Spec D tuning. They are all for show, and that's about it...
Thinking about getting the 08-10 projectors now or getting them retrofit with lightwerkz.net
check this guys out! I love it: https://www.scionlife.com/forums/sho...d.php?t=147363
Old 09-13-2009 | 07:01 AM
Are the oem ones easy to aim? or do they even need aiming?
Okayyy...so I have my pictures! I just took them. I figured out why some of the light is so effed up. The bulb itself isn't fitting correctly for some reason on the drivers side. I would push down on the bulb and it would make a huge difference (wider and better cutoff) I don't know how to fix this though. It is the type with the spring that snaps over the bulb, not the twist like the stock headlight.
anyways, tell me what you think. Here are my pics. I know...they are soo FUBAR!!
Attached Thumbnails Aiming projector Headlights help-img_0181.jpg   Aiming projector Headlights help-img_0184.jpg
Old 09-13-2009 | 07:12 AM
DJ08tC's Avatar
Wow those are pretty bad, Lol. Now these aren't the best pics because I dont have a good camera or a good spot around school. These are 08s with 4300k HIDs.
