ANZO Tail Light Problem
Old 08-29-2007, 03:49 PM
STNC's Avatar
I don't know how, I keep blowing fuses, andt they are hard to find....
STNC is offline
Old 08-29-2007, 04:10 PM
andrewStC's Avatar
2007 tC here with Anzos. Mine were blinking fast too, but I plugged it the other way and both work fine now, normal speed blinking, everything lights up. I've had these tail lights for 2 months or so now.
andrewStC is offline
Old 08-29-2007, 04:22 PM
STNC's Avatar
I assume you bought them from ebay? can you please post some pictures of the wiring connections? that would be sooooo helpful
STNC is offline
Old 08-29-2007, 04:24 PM
Mid_Life_tC-risis's Avatar
You shouldn't be blowing fuses on this install. Are you disconnecting the battery when plugging in the lights?
You also need to disconnect the battery again before you switch plugs around while troubleshooting. I know we didn't mention this earlier - it's kind of implied that you would have the battery disconnected any time you're hooking up the lights.
The battery should only be re-connected when you have all the lights plugged back in.
Mid_Life_tC-risis is offline
Old 08-29-2007, 04:38 PM
STNC's Avatar
o....
so I'm assuming disconnecting the negative?
STNC is offline
Old 08-29-2007, 05:09 PM
andrewStC's Avatar
nah, I bought mine from fastscions.com, but it's the same as yours because on my box it says eagle eyes.
Old 08-29-2007, 05:47 PM
Keeshwah's Avatar
Dude, your logic is painful to read. Did you try flipping the connectors yes or no? And don't ask me if I have an 07. A bunch of ppl said flip it, did you try that?
Keeshwah is offline
Old 08-29-2007, 05:59 PM
RodC's Avatar
Do you have an 07? Lawl.
RodC is offline
Old 08-29-2007, 10:21 PM
Yes, disconnect the negative battery terminal. Replace any blown fuses - if you're out of spares take the blown fuses to a dealer or get them from Autozone or any chain auto parts store. Hook up your tails. Reconnect the batt & check how your lights are working.
If they're still blinking fast, disconnect the neg. battery terminal. Reverse one turn signal connector at a time until they work right, always making sure the battery is disconnected when handling the connectors.
If you're not using a procedure for reference here's one:
http://trdsparks.com/install/00016-21550inst.pdf
Old 08-30-2007, 02:35 AM
STNC's Avatar
So i got mine to work, i just pulled all of the prongs out, and then i just tried different combinations with a 9V battery until they lit up. Then i used the pictures from the other led tail light DIY to find which way to plug them in.
My only current problem is that my parking lights wont turn on, and i cant find the fuse for it. All of the fuses inside the cabin are good.
STNC is offline
Old 08-30-2007, 05:28 PM
Check your owner's manual for fuse locations. They may be in different spots in the cabin or in the engine compartment.
xBSciontist
06-18-2019 03:06 PM
Cadillac15
01-29-2015 07:34 AM
snappe2
01-27-2015 05:29 PM
TheTripleC
01-04-2015 06:46 PM
mrbadass03
24
04-21-2004 02:17 AM
Quick Reply: ANZO Tail Light Problem
