Badgeless Upper Grille Mod??
Old 01-10-2008 | 04:59 AM
viventi's Avatar
Default Badgeless Upper Grille Mod??
I know a few people on here have done this, whats the easiest way to go about fitting/cutting a lower grille to fit in the upper? how do you mount it?
i was thinking about doing this or going with maybe vrd's. but i'd like to give this a shot.
i did a search but the DIY thread that came up was locked and the OP's post was deleted
Old 01-10-2008 | 05:00 AM
trentonm's Avatar
take a stock lower one, place behind the stock upper one... make appropriate marks clip, zip tie and mount.
Old 01-10-2008 | 07:05 AM
Dakine's Avatar
Concept in Motion Crew
no no...
take upper chrome trim, detach from upper grill. place on lower grill and mark from there.
Old 01-10-2008 | 07:54 AM
trentonm's Avatar
what would be the difference? you still see where they connect....
Old 01-10-2008 | 07:58 AM
SengTC3's Avatar
I'll give you 1 advice, DON"T F*CK UP haha, mines has a weird gap =/
Old 01-10-2008 | 08:01 AM
Dakine's Avatar
trust me. i've done many many badgeless upper grill mods for customer and i've done alot of different varieties. the way i said works the best from my experiences.
Old 01-10-2008 | 08:25 AM
SengTC3's Avatar
hey dakine your from the bay right?
Old 01-10-2008 | 06:06 PM
Dakine's Avatar
yes sir!
Old 01-10-2008 | 06:11 PM
rosedaleny806's Avatar
i wanna do the same but i have 2 stock grilles i dont wanna use the bottom grill, wat can i do from here? lol
Old 01-10-2008 | 06:18 PM
Dakine's Avatar
u can do how my current grill is. cut the circle off ur top, take a bottom grill and apply a portion on there. either way u need another grill.
Old 01-10-2008 | 06:58 PM
o so i need the bottom? i was wondering if i can jus use one of my tops for scrap
Old 01-10-2008 | 07:41 PM
Dakine's Avatar
whoops, yes top or bottom grill for extra honeycomb will work. i used the sides on another spare upper to do mine.
Old 01-10-2008 | 08:21 PM
SengTC3's Avatar
try to look locally for a bottom grill, go to scion meets and someone with the bottom grill foggies might have their stock bottom grille left around and might sell it for cheap, I got mines for $20.
Old 01-10-2008 | 08:36 PM
trentonm's Avatar
thanks man, just unaware of that difference... good to know
Old 01-10-2008 | 08:45 PM
ok so when i cut the circle off how do i actually put it together with like glue or sumthin?
Old 01-10-2008 | 08:52 PM
Dakine's Avatar
i use jb weld. sanded it and painted.
Old 01-14-2008 | 10:08 PM
viventi's Avatar
wanna just do one for me? ahahah. im lazy/dont trust myself
i'm still debating. this or the vrd grille/fog package.
Old 01-15-2008 | 03:35 AM
AtC's Avatar
AtC
i was also thinking of going for the badgeless oem grille
but i dont really have the guts to do something like that,
so i was thinking of buying the vrd grille as an alternative
but dont really want to. so the EASIEST way is to. . .
1. cut the scion emblem and weld the piece together
2. buy a lower grille
or
3. dont do nothing at all
Old 01-16-2008 | 02:17 AM
ilovemytC's Avatar
This was my first mod and it looked awesome. The way I did it was make cuts in the bottom of the grille for the chrome trim tabs. Instead of 3M taping it together, I just used some cement glue to keep the tabs from popping off of the grille. If you would like a better explanation, PM me. Pics:
Old 02-26-2008 | 07:35 AM
ALaS's Avatar
I say you do a write up!
