bake open headlights
or if you feel 315 is too high, my friends and i do it at 225 for 15 min and it works perfect.
also if you change your mind on smoking the side markers my friend and i sell clear corners for 20shipped.
Read this should walk you through it. Its what we referred to when we did mine.
https://www.scionlife.com/forums/vie...767&highlight=
i noticed theres nothing in that one about applying new sealant on when putting them back together...moisture buildup would be aweful i only wanna do this once haha. what would you guys recommend as a sealant?
Take the 4 Screws out from the backside.
i set my oven at 250 for 15mins...
then pull apart w/ oven gloves & a flathead screw driver!
Then re-heat the adhesive then put back together!!!
alright sounds easy enough.
i was readin up on the clear corner thread and RodC baked his and didnt use anything either so i think i'll be set. just found that thread so sorry for the repost, im going to attempt tomorrow so ill be back with results
I went to Ace hardware and went to the glue section and found a clear sealant that was marine grade and after re-baking them and putting the screws back in I ran a bead around the whole headlight and haven't had a problem.
