View Poll Results: Which Retro set of headlights
Voters: 4. You may not vote on this poll
Choices for retro headlights
Story is i want to retro a set of headlights for my tC.
Questions are should i use the oem housing, the anzos that look like THIS
Things to know:
I will be using tsx projectors. If needed i will used the e46 shrouds.
If i chose the anzo's i wont use the led's on the top eyebrow, i only like them for the halos and no use for a shroud.
What i dont like about the oem is when you use a shroud from what ive seen theres a gap in the top corners of above the shroud and on the sides
Opions?( good, bad,constructive)
Things to know:
i'd use the OEM housing because they will always be the highest quality. and if you want halo's, you can always get what you need from somewhere like oznium to make your own halos. and you can do something with that gap in the corner if it really bothers you while your making your retro fits. maybe put a small running light there or something,
BlingSlade
10-19-2016 01:39 AM
